Help??? P0141 Code?
ETHACK
nv
2001 XLT AWD 4.0L
Ok got motor in and is running but this code keeps popping up says "P0141- O2 sensor Heater Circuit Bank 1 Sensor 2 " now I'm led to believe that is the passenger rear O2 sensor, right? Now other ?? is does this mean that O2 sensor is bad or is catalytic converter is going bad?? Also, does this effect the motor running in anyway too lean/rich,etc??? TIA you guys are great, this will be our traveling rig and must be 100!!!
donalds
Location
Stem
Nc
1999 ford explorer sohc
Bank 1 sensor 2 is the passenger rear o2 sensor
There will be a separate code p0420 I think if you had a bad cat look for a bad wire or the sensor itself
That's where I would start
If you just had the engine out maybe look by the trans bellhousing where the connections are you must have disconnected them to get the engine out
ETHACK
nv
2001 XLT AWD 4.0L
Yea thats what I was thinking the 1 up at bellhousing/manifold would be Sensor 1 not 2 right or are the wires on same circuit, will double check though as still got fender wells off so easy to reach I'm hoping its not the cat but if so then probably do ex system. O2 sensor alot cheaper though. The back sensor do you know if it effects the fuel/air mixture or is that only the #1 sensors?
donalds
Location
Stem
Nc
There are two connections in that area a big one and a o2 sensor one the o2 sensor connector is for the front sensor but I think the other connector has your wires in it try to reseat it
M Help! 1997 Ford Explorer 4WD V6 4.0L SOHC Code P0141 Stock 1995 - 2001 Explorers 2
L help with p0141 and p0161 Stock 1995 - 2001 Explorers 4
G Spare part ordering issue? Please help.. Stock 1995 - 2001 Explorers 23
V 1999 XLT Problems...Please Help Stock 1995 - 2001 Explorers 8
M Radio with no sound 95 explorer please help Stock 1995 - 2001 Explorers 2
S 98 explorer HELP!!! NEW alternator put in, mechanic says stuck in "anti theft" stealth mode **UPDATE**WAS THE STARTER -NOW BALL BEARINGS BRAKES/ROTORS Stock 1995 - 2001 Explorers 47
sattech2000 Help reading spark plugs! Stock 1995 - 2001 Explorers 9
9 Exhaust pipe STUCK! What a PITA! Need help please... Stock 1995 - 2001 Explorers 15
F Help! Brakes suddenly go out and I frantically pump them and car accelerates for a second. dude am I CURSED Stock 1995 - 2001 Explorers 14
L Need HELP with finding where a single wire goes Stock 1995 - 2001 Explorers 4
0 Need help with fog lights Stock 1995 - 2001 Explorers 5
T Need help with new water pump fan Stock 1995 - 2001 Explorers 18
D Help..Plz..Transmission problem Stock 1995 - 2001 Explorers 14
M High idle and sluggish shifts. Need help! Stock 1995 - 2001 Explorers 12
J HELP Trans went out out of nowhere. Stock 1995 - 2001 Explorers 10
J Help car wont start Stock 1995 - 2001 Explorers 5
C 2000 Explorer EB,Help needed no power to fog lights radio cutting in and out after replacing starter Stock 1995 - 2001 Explorers 0
Z Sunroof not working Help! Stock 1995 - 2001 Explorers 7
H Need help with my mounty Stock 1995 - 2001 Explorers 1
N Help me determine what year 5.0 I have? Stock 1995 - 2001 Explorers 7
E **HELP** Strange Noise Stock 1995 - 2001 Explorers 15
D Need help identifying part Stock 1995 - 2001 Explorers 3
S Wont sift need help Stock 1995 - 2001 Explorers 1
Z Possible thermostat problem need help Stock 1995 - 2001 Explorers 13
C Wiring help. Stock 1995 - 2001 Explorers 0
M Hi, super glad to be here and I really need help. Stock 1995 - 2001 Explorers 12
R Solved Help needed for identifying a vacuum hose on the throtte body. Stock 1995 - 2001 Explorers 7
N 1999 Ford Explorer problems - help? Fixed..not fixed.. Stock 1995 - 2001 Explorers 53
C Vacuum Reservoir? HELP! Stock 1995 - 2001 Explorers 10
S Help Please! Valve cover wont come off Stock 1995 - 2001 Explorers 2
Cuco NEED HELP FIND PART Stock 1995 - 2001 Explorers 1
Brem95 Messy leak help ID? Stock 1995 - 2001 Explorers 10
S Help diagnose random misfire Stock 1995 - 2001 Explorers 12
E 97 V8 AWD help diagnosing leak from accident Stock 1995 - 2001 Explorers 20
S HVAC Help! Stock 1995 - 2001 Explorers 5
J Help with camshaft placement sensor and fuel pressure regulator Stock 1995 - 2001 Explorers 15
B 3rd light trial and error need help Stock 1995 - 2001 Explorers 7
G Anti-theft alarm going crazy - help Stock 1995 - 2001 Explorers 3
C 98 4.0 x-vin ohv exhaust help Stock 1995 - 2001 Explorers 5
M Help, transfer case locked up in 4wd Stock 1995 - 2001 Explorers 9
Z Tranny issues that need help Stock 1995 - 2001 Explorers 5
donalds trans pan gasket help please Stock 1995 - 2001 Explorers 25
E help - occasional highway RPMS surge to 4200 but Speed only 60? Stock 1995 - 2001 Explorers 10
T Coolant Leak Help Stock 1995 - 2001 Explorers 3
E 1999 Explorer needs a bit of help Stock 1995 - 2001 Explorers 5
L Help Stock 1995 - 2001 Explorers 8
R 98 tcc help Stock 1995 - 2001 Explorers 1
B 2001 Ford Explorer Sport. New MEMBER. HELP PLEASE! Stock 1995 - 2001 Explorers 10
B Upper intake gasket help Stock 1995 - 2001 Explorers 6
M Loves older explorers need help asap Stock 1995 - 2001 Explorers 18
Similar threads
