Help, Phantom Misfire
Explorermandan
Oregon
2002 explorer limited v8
Hi,
I have a misfire on my 02 limited explorer. It runs ok when cold, but once it warms up, it has a rough idle, and misfires under light load in lower rpms. At WOT, the engine surges and the HP curve is not smooth at all.
I've ran fuel injector cleaner twice, changed the plugs, and changed the COP's. As a result of my efforts, the trouble codes indicate that after each attempt to fix it, a different cylinder goes bad. Right now it says that cyl 1,2, and 8 are misfiring.
Any Ideas? It seems odd that the problem would move, and correct me if I'm wrong, but those cylinders are on different banks, so its probably not an O2 sensor? Is the car sensitive to the type of COP's? I replaced all with Granetelli's from summit racing.
The truck is all stock except for a CAI from my '00 mustang. It also has the Mustang Mass air sensor, but its run fine for over a year.
Help please!
rocco123
Endicott, NY
1994 XLT & 2002 Limited
Have you looked at that 90deg rubber elbow that leads into the idle air controller? Also look for other vacuum leaks.
pet575
Kansas City, MO
2004 Limited
Possible short in the wiring feeding the COPs? Might be a reach but sounds like you might be at that point anyway.
Adam Black
98 Explorer sport 4.0 OHC
Have you check the spark plug wires? If those have any excessive resistance/opens or abrasions, it can cause misfires.
rocco123
Endicott, NY
He mentioned cyl 8. So its a v8. No plug wires just coil on plug COP
Explorermandan
Oregon
Thanks for the replies. I've glanced around for vacuum leaks, but I'll look closer tomorrow. I thought about the cop wires being loose, but if it's moving around, I kinda ruled that out.. it's worth a look though! crossing my fingers..
zpn_by
Ontario
2002 Explorer EB
What brand replacement COP part did you use? I've heard varying reports about the reliability of many off-brands. Honestly it sounds like you're working on my truck as I had the exact same misfire pattern you did. #1, cleared, drove OK. #2, cleared, drove OK. #8 Cleared, drove ok. Funny thing was it actually ran better with the CEL on solid than when it was off...
When you changed your coils, did you reuse the boots, or did you at least run some dielectric grease inside the opening (not so as to get on to the plug contact itself though... I finally got my code to repeat on a saturday when I had my sockets and scanner handy, and chased it down to a bad #1 (consistently). Went to the wreckers, and got myself three newer motorcraft coils (funny thing, all the engines had replacement COP's on them - wonder why...) I replaced the faulty one and now keep my scanner and the two spare COPs in the trunk....
+1 on checking the wiring. Also double-check the connections for your cam sensors - if you are in a moist/wintry area the connections may be corroded. Possible that although they aren't throwing codes they may think they are registering a misfire. Did your CEL blink or just come on solid?
rocco123
Endicott, NY
I used accel. Amazon for 200. They come withboots and yes dilecteic grease. Tore an old boot tip due to being stuck.
Explorermandan
Oregon
sorry for the delay, I used granetteli cops. I checked for vacuum leaks and couldn't find anything. all the wiring looks and feels intact. This all started happening shortly after having the fuel filter changed along with the oil. maybe some debris went up the line and its messing with the injectors? the cel came on and didn't blink. I'll look into the cam sensor wiring. I've also read reports that if the wrong engine oil is used, it can also cause misfires. that makes no sense to me, but that's a cheap fix if that's the issue.
Explorermandan
Oregon
also, I used plenty of dielectric grease. I was under the impression that too much was ok, and it was supposed to be in contact with the boot wire as well as the plug post.
JCUZ
Canberra, Australia
2004 Explorer Limited V8
I have a misfire on mine - #5 cylinder (closest one to thermostat housing). My CEL only ever blinks - what does that mean as opposed to a solid CEL light? I have 3 different sets of COPS (so 24 all up), and when I get the misfire, I simply change the hot COP from #5 for a cold one, and off we go again, until it does it again 5 miles down the road (literally). Very frustrating.
zpn_by
Ontario
2002 Explorer EB
First things first, if it blinks, pull over & power off ASAP. It means there is a misfire which may be dumping raw gas (or LPG) into your exhaust and possibly damaging your catalytic converter.
Big question for you - does it only happen when running LPG or gasoline? If when on gasoline, you may have a bad injector, if when on LPG, that's beyond my experience. Is your LPG system running multiple injectors? It could also be wiring too, or even the boot or plug itself. Have you changed the spark plugs recently, and did you use anything other than Ford Motorcraft? These engines (so I'm told) are very finnicky with plugs... Are you actually getting the P0305 code? It could be a loose connection on that COP, or a brittle/broken wire too, if it is that code.
I know it's lots to check or confirm, but these were steps I went through with troubleshooting my truck. I ended up getting three Motorcraft COP's from the local wrecking yard. I changed the bad one, and keep the two extras as spares. At least there is lots of storage space in the truck, so I have my code scanner, basic hand tools, and a full socket set with me at all times. Too bad that I have to, but I can't swing the $$ for a whole new set of COP's...
rocco123
Endicott, NY
Check the torque of the plug to be sure its not ready to spit one out.
zpn_by
Ontario
2002 Explorer EB
be careful checking the torque - the problem of stripped threads can come from over torquing the plugs. If it's spit one out, you'd know for sure, plus it would come with the boot when you remove the coil. That was a big problem on many trucks, but I'd wonder if the LPG is causing a problem for JCUZ (although in my city, the 4.6L Crown Vic cop cars are all LPG and don't seem any worse for it)
JCUZ - check your alternator's condition and output - if there isn't enough juice, then the COP at the end of the circuit might be suffering. In this case #1 or #5. I've heard from users on other forums that an underperforming alternator could cause spark problems too.
S Please Help, 2002 standard 4x4 explorer wont go into gear when started Stock 2002 - 2005 Explorers 10
J Power lost, No codes, Good idle.... Need help please... Stock 2002 - 2005 Explorers 0
A Need help with idle problems Stock 2002 - 2005 Explorers 5
S Need help identifying sensor and brake issues Stock 2002 - 2005 Explorers 1
B Help! Which parts do I need? Stock 2002 - 2005 Explorers 9
J Need a little help fight in the condensation drain on a 2002 Ford Explorer XLT Stock 2002 - 2005 Explorers 0
H Please help with oil pump replacement in vehicle. Stock 2002 - 2005 Explorers 4
N 2002 does explorer xlt transmission help Stock 2002 - 2005 Explorers 0
V Help Stock 2002 - 2005 Explorers 0
A NEED HELP ! Can't Pump Gas Into Vehicle Properly GAS Pumps Click off After Pumping Just a Few Cent Stock 2002 - 2005 Explorers 4
Y Help! I can't find chrome mirror caps! Stock 2002 - 2005 Explorers 0
M specialy producsts 86140 installation help Stock 2002 - 2005 Explorers 0
B Need help Stock 2002 - 2005 Explorers 2
W Needing some help Stock 2002 - 2005 Explorers 0
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
H need a little help please Stock 2002 - 2005 Explorers 1
W Help Misfire Stock 2002 - 2005 Explorers 1
W Age old timming help Stock 2002 - 2005 Explorers 7
O P0152 Code - Help!!! Stock 2002 - 2005 Explorers 4
H Serious Misfire, Please help Stock 2002 - 2005 Explorers 2
J Body Work Help Stock 2002 - 2005 Explorers 4
S Transmission Help Stock 2002 - 2005 Explorers 2
K Help me Stock 2002 - 2005 Explorers 5
B Help Selecting a OBD2 scanner Stock 2002 - 2005 Explorers 26
L Overheated Explorer, need help or engine Stock 2002 - 2005 Explorers 0
D Help! Tranny hung in 4th gear. Stock 2002 - 2005 Explorers 2
P Help with part#. 04 XLT 4.0 SOHC Stock 2002 - 2005 Explorers 6
A 2004 XLS low beams not working - please help Stock 2002 - 2005 Explorers 4
M Rear Sway Bar End link Replacement help Stock 2002 - 2005 Explorers 3
A Help! Fuel pump. Stock 2002 - 2005 Explorers 0
H 2002 ex sport 2 door rocker panel help. Stock 2002 - 2005 Explorers 3
H Need help with parents 02 explorer(rear axle?) Stock 2002 - 2005 Explorers 6
S Need help with wiring Stock 2002 - 2005 Explorers 0
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
A HELP! 2005 Ford Explorer Fuel Pump ???? Stock 2002 - 2005 Explorers 15
M Problem starting after changing valve cover gasket. Please Help Stock 2002 - 2005 Explorers 4
I I need help with a power drain on my battery Stock 2002 - 2005 Explorers 1
M Please help with this noise also smoke and oil Stock 2002 - 2005 Explorers 7
A Help!! Control arm /end link bushing failure Stock 2002 - 2005 Explorers 12
S Help with a random misfires problem P0300, P0303, P0304, P0316 Stock 2002 - 2005 Explorers 3
R Help with Sonnax Servo replacements... Stock 2002 - 2005 Explorers 7
P '05 XLT V6, P0303 & no compression -- head gasket? valve? piston?-- pls help diagnose (video) Stock 2002 - 2005 Explorers 10
B Timing chain problems pls help Stock 2002 - 2005 Explorers 1
S Brake help needed with 02 Explorer Stock 2002 - 2005 Explorers 4
E Help finding rear ABS sensor Stock 2002 - 2005 Explorers 2
Z ID sticker. Help needed. Stock 2002 - 2005 Explorers 6
J 04 Ford Explorer mom needs help Stock 2002 - 2005 Explorers 17
S New to the site and need help Stock 2002 - 2005 Explorers 2
M Crank no start. Please help Stock 2002 - 2005 Explorers 5
J Help/ repair Stock 2002 - 2005 Explorers 10
Similar threads
