Bipeman
- January 4, 2013
- Dallas Texas
- 2005 Ford Explorer
- Callsign
- KS5O
2005 XLS 205K mi. Heading down the road the other day I experienced what felt just like running out of gas. Truck shuddered and stalled at a light, re-started and went a block or two, rinse-repeat X-3 times and then basically quit, except... cranking resulted in the engine firing up for a second or two then chugging for a few seconds and quitting.. repeatedly.
Had it towed home and decided it was time to change the fuel pump. Figured it should be done in any case at this mileage. Installed a new Delphi pump. Did not change the (original) fuel filter at this time (I know.. I know). Eureka.. the car fired up and ran fine.. for about 30 miles. Next morning.. the problem began to manifest again... made it home.. about 10 miles.. with the truck nearly stalling at traffic lights, and finding that keeping it revved up seemed to prevent this for the most part.
OK... should have changed the fuel filter .. duhh.. Did that. Found the filter to be pretty clogged up and had some black crap come out of it on the engine side as well.. Was pretty sure this had to be the problem... Nope! Same trouble. Truck will start, run 2-3 seconds.. then start to misfire.. chuggetty chug on for several more seconds and quit. From time to time it will suddenly start to run fine, for one minute plus, in park, when rpm is held up to 2500 or so with foot on the pedal.. then it starts running a little rough, then RPM drops.. more chug-etty chug, and die.
The only code I am getting is 2197 -- O2 sensor.
Spraying starting fluid into one of the vacuum ports (the one net to the power brake vac line) gets her running and seems to keep her running (smoothly for the most part) although I did not want to do that for very long.
Questions come to mind... Did the new pump fail? Did the clogged filter cause that and possibly the failure of the original?
I think the next step is a fuel pressure test. Also a problem with the fuel pump relay comes to mind but seems a bit of a stretch as this would likely be all or nothing.
Sure would appreciate any help.. thanks in advance!
