hottrodk10
- March 5, 2016
- Citra, FL
- 1998 Ford Explorer 4.0ohv
ok.... thought I had posted 2 mos ago .... here goes again. 1998 explorer 4.0L sov engine, ran great until I changed the(stuck open) thermostat, Temp sending unit, & ECT in January. then started not wanting to stay running after its ran at temp and then shut off for 15-20 mins(starts, idles up then idles like a flooded out carb ). if you crank it right after shutting it off then it fires up and runs fine. if you wait it fires up and runs like a flooded carb(instant :thumbdwn: gas mileage too now) . New Fuel filter, Battery, CPS, MAS, new plugs, wires, Fuel pressure regulator, cleaned IAC.... changed second ECT just in case the new one was faulty. just realized that the sending unit Advanced sold me has 2 blades--my plug is a single... had one mechanic tell me everything checks out perfect, that my injectors are "dirty" & to run Seafoam thru(did). Another just told me that the double blade sensor with my single blade plug could be messing up the ECT talking to the computer????? The diagnostic did show that the actual engine temp and what the gauge showed is off with this sending unit? -- this is my only vehicle and I'm having to do the work on it(yes, I'm a girl ) -- any thoughts would be Greatly appreciated
