Help Please! Acceleration deadzone until kickdown
mfitz725
03 EB 4x4 4.6l making it thru in NC
Location
Albemarle NC
Albemarle NC
'03 Eddie Bauer 4.6L 4x4
My 94 Explorer runs very normally day in and day out. However, when I drive it for a couple of hours on the interstate basically non-stop at 70-80 MPH it develops a problem. The check engine light will randomly illuminate and when I try to accelerate nothing happens until the pedal hits the point that kick down occurs. Then it will pick up speed.
If I pull of the road and sit still with foot on the brake it begins to surge, for lack of better way to put it. If I let it sit for a bit, maybe 10-15 minutes there is no more surging and it seems to accelerate close to normal again all the way through the pedal position range. Problem reoccurs after driving on for about 15-30 minutes.
Once home and it cools all the way down it acts completely normal again.
Anybody got any ideas? (It got new plugs, wires and a TPS late in the summer)
gmbroy
Orange VA
1996 explorer Eddie Bauer
take a close look at your temp. & make sure it isnt getting a little hot . If you could install a mechanical guage to give you a true reading would be the best . maybe put some heat protective wrap on the 2 fuel lines . Hope this helps you some :salute: If not holler at us & we will do our best to help you
D Please help this lady Stock 1991 - 1994 Explorers 8
J Bad misfire please help Stock 1991 - 1994 Explorers 2
A Under hood wire harness. HELP (please) Stock 1991 - 1994 Explorers 12
9 1994 Mazda B4000 4x4 Problems Please help. Stock 1991 - 1994 Explorers 4
S Help PLEASE Stock 1991 - 1994 Explorers 3
G My 1994 explorer...the right brake light and blinker wont work with a new bulb. PLEASE HELP!!! Stock 1991 - 1994 Explorers 2
D NO HEADLIGHTS 1994 FORD EXPLORER - HELP PLEASE Stock 1991 - 1994 Explorers 3
N Please help With auto trans Stock 1991 - 1994 Explorers 5
R Help please with timing chain Stock 1991 - 1994 Explorers 3
M (Brake calipers, "death wobble?", shaky steering) Please help!! My baby is sick!!!! :( Stock 1991 - 1994 Explorers 89
G sunroof problems help please Stock 1991 - 1994 Explorers 9
C Automatic to manual hubs, please help!! Stock 1991 - 1994 Explorers 14
B lsd help please Stock 1991 - 1994 Explorers 13
B need help with transmission install please help Stock 1991 - 1994 Explorers 11
M 94 explorer help please Stock 1991 - 1994 Explorers 5
B 4x4 Instructions help please Stock 1991 - 1994 Explorers 14
9 Problems with Motor rebuild! Please help. Stock 1991 - 1994 Explorers 7
V Uk based member with 1st gen, help with fault codes please. Stock 1991 - 1994 Explorers 4
T no brake lights need help fast please Stock 1991 - 1994 Explorers 7
N *Help please* Check engine comes on when warmed up + gets louder/rumbly Stock 1991 - 1994 Explorers 4
G transmission dumped. please help! Stock 1991 - 1994 Explorers 2
J Please Help!!!Front drivers side break get burning hot in my 94 explorer!!! Stock 1991 - 1994 Explorers 10
B Strange electrical issues help please Stock 1991 - 1994 Explorers 26
J Please help me with my stupid roof rack issues Stock 1991 - 1994 Explorers 17
A Shifter bushing...please help! Stock 1991 - 1994 Explorers 3
S Help please. Stock 1991 - 1994 Explorers 7
S tired and confused. help please. Stock 1991 - 1994 Explorers 3
C Please help transmission wont shift into Drive Stock 1991 - 1994 Explorers 1
C Please help transmission wont shift into Drive Stock 1991 - 1994 Explorers 13
F Help Please! not covered Power Lock Issue Stock 1991 - 1994 Explorers 5
C Lost clip please help Stock 1991 - 1994 Explorers 0
S Somebody please help! 94 ford explorer grinding and clunking! Stock 1991 - 1994 Explorers 7
H Rough idle, spitting carbon...Please, I NEED YOUR HELP. Stock 1991 - 1994 Explorers 2
C Transmission help please! Stock 1991 - 1994 Explorers 8
C 92 stock- need help please Stock 1991 - 1994 Explorers 3
S Ignition, fuel, maybe air? SERIOUS PROBLEMS PLEASE HELP Stock 1991 - 1994 Explorers 3
9 u joint to cv shaft please help Stock 1991 - 1994 Explorers 4
M AC Problem ... Please Help Me !! Stock 1991 - 1994 Explorers 20
9 PLEASE HELP vacuum lines popping off the vacuum tree Stock 1991 - 1994 Explorers 16
L 94 Explorer Transmission possible problem, Please help... Stock 1991 - 1994 Explorers 1
S help please Stock 1991 - 1994 Explorers 4
M Door latch on 1993 Ford Explorer. Help Please Stock 1991 - 1994 Explorers 3
A Passenger Side Front Inner Bearing Won't Go On...Please Help! Stock 1991 - 1994 Explorers 6
C Please Help- Trani head scratcher Stock 1991 - 1994 Explorers 6
J Please help daily driver down Stock 1991 - 1994 Explorers 3
S Please help with o/d problem Stock 1991 - 1994 Explorers 5
H Dash needle color change and Gauge over lay help please Stock 1991 - 1994 Explorers 3
T Transmision problems please help Stock 1991 - 1994 Explorers 0
9 91 navajo no fuel or fire PLEASE HELP ME!!! :-( Stock 1991 - 1994 Explorers 15
G frustrated beyond belief, please help Stock 1991 - 1994 Explorers 26
Similar threads
