meyek91974
- August 21, 2008
- Louisville, Kentucky - Let me no f u r nearby
- '99 Explorer 2wd Edd.B
How can I remove the fuel line from the gas tank fuel pump when using the disconnect tool does not work? The fitting will rotate and can push back and forth about one-sixteenth of an inch but will not pull off no matter how I try. I just replaced the fuel filter and had to quick disconnect lines there which work fine however the fuel line at the top of the gas tank at the fuel pump will not release no matter what I do. Please help with tips
