Exp1992
- October 24, 2006
- 92 XLT
This is an intermittent problem. 1992 Explorer engine idles fine. But once driving engine starts out OK but then runs rough where engine power sputters down like running on 3-4 cylinders, and RMPs drop to around 1500 until it instantly changes to running normal again. It's either bogging down or it's running normal. Problem exists when engine is either cold or warm (normal temp). Read trouble codes several times, keep coming up 111.
Inspected wires, they look fine (no crack and only a few years old). Put fuel injector cleaner in during last tank full. Already changed fuel pump, fuel filter, fuel pressure regulator, MAF sensor, ignition coil box, and new spark plugs.
Could it possibly be the EDIS module or crank shaft position sensor?
Suggestions?
Thanks!
Suggestions?
Thanks!
