Help Please!!
sslinn
2015 Explorer XLT
I have a 2002 Ford Explorer and the hood will not open.
When I pull the release level there seems to be tension on it, but nothing happens.
If you have any ideas it would be appreciated.
Thanks,
Shayne
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
BrianDye
I'll have another...
Monroe, MI
2006 XLT
Try pulling harder?
Have you adjusted the hood latch at all?
Back when I had my '92, the hood seemed a little "high" when it was closed, so I loosened the hood latch, and lowered it a little, and the hood closed a little harder, and then when I went to pop it back open (Pulling on the lever) it seemed nearly impossible to pop because it was so tightly latched.
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Thanks,
Shayne
The tension is likely from the return spring which is in the release handle assembly, not the actual underhood mechanism.
It is more likely that your cable is broken.
I would first recommend confirming this by having someone pull on the release lever while someone else observes the latch mechanism, through the grill (you may only be able to listen to it).
Then go from there. If the latch is not actuating, I would remove the release mechanism, find the cable and pull on it directly using vice grips or equivalent. If it does nothing, you have your answer.
If the cable is bad, I think you'll have to loosen the grill (hard to do with the hood closed) to manually actuate the latch.
Try the search option, I think this has come up before on this forum.
jtrasap
Altamont, IL
04 mounty
Have you tried pulling the handle and then giving the hood a couple thumps right where the latch is? Or, maybe the cable isn't quite pulling the latch open far enough to release it? If thumping the hood doesn't work, you could try pulling the handle, then taking some pliers and pulling the cable out a bit further and see if it unlatches. Once you get it open you may want to spray the latch down with some wd40 to make sure it's moving freely.
sslinn
2015 Explorer XLT
Thanks for the help guys. I haven't adjusted anything.
I will try your suggestions. Crossing my fingers.
sslinn
2015 Explorer XLT
Thanks guys! I hear it moving and then a couple of bumps while the release was being pulled worked!!
I appreciate your quick replies.
FordRacer28
Michigan
1994 XLT 4x4
you can cut the cable and run it threw the grill and tire a 1 inch washer to it if you wanna do it that way i had to do it to my old 84 blazer also to my 88 blazer... but then i woke up one day and relized FORD is the way!!
stuartr
Richlands, VA
2002 Mercury Mountaineer
If you have it open put some WD-40 on it to loosen things up, then put some oil on the latch so it won't happen again.
STU
EasyRhino
Kailua, Hawai'i
STU
:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
H need a little help please Stock 2002 - 2005 Explorers 1
H Serious Misfire, Please help Stock 2002 - 2005 Explorers 2
A 2004 XLS low beams not working - please help Stock 2002 - 2005 Explorers 4
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
M Problem starting after changing valve cover gasket. Please Help Stock 2002 - 2005 Explorers 4
M Please help with this noise also smoke and oil Stock 2002 - 2005 Explorers 7
G '05 Explorer V8/5R55S - metallic SHHHH noise on acceleration, source help please Stock 2002 - 2005 Explorers 0
M Crank no start. Please help Stock 2002 - 2005 Explorers 5
P Jammed Hatch ----- Please Help Stock 2002 - 2005 Explorers 1
V Help please - timing chain problems Stock 2002 - 2005 Explorers 2
N Emergency! Please Help! 2003 Eddie Bauer 4.6L Stock 2002 - 2005 Explorers 4
4 Radio help please Stock 2002 - 2005 Explorers 2
J Hello help please! Stock 2002 - 2005 Explorers 5
S Check Charging System Warning PLEASE HELP Stock 2002 - 2005 Explorers 2
R HELP PLEASE!!! P1151,301,302,303 Stock 2002 - 2005 Explorers 16
O please help 05 mountaineer no crank, security light flashing fast, had bad ground term Stock 2002 - 2005 Explorers 13
B Please help me figure out what this piece is called! Stock 2002 - 2005 Explorers 7
G Need help with new engine selection please. Stock 2002 - 2005 Explorers 5
M Running Rough - Please Help!!!!! Stock 2002 - 2005 Explorers 15
R Whats this noise? Help please Stock 2002 - 2005 Explorers 5
S 03 4.6L Temperature guage not working, Help Please! Stock 2002 - 2005 Explorers 4
Ddudley84 4x4 problems please help Stock 2002 - 2005 Explorers 2
M Please help Stock 2002 - 2005 Explorers 1
P Help with a/c issues please Stock 2002 - 2005 Explorers 3
W hello and please help Stock 2002 - 2005 Explorers 11
X Help please no crank no start Stock 2002 - 2005 Explorers 35
W Please Help me, HPTuner Scanner log file attached Stock 2002 - 2005 Explorers 7
P Please help me, engine still won't turn over Stock 2002 - 2005 Explorers 22
A Help please - Need Part # for Clock Spring - 2005 Ex EB 4.6 with Traction, Audio Controls Stock 2002 - 2005 Explorers 2
R PLEASE HELP! NO ENGINE POWER Stock 2002 - 2005 Explorers 71
D Transmission Confusion - please help Stock 2002 - 2005 Explorers 15
C Trying to identify this part - please help Stock 2002 - 2005 Explorers 8
C Please help! 2002 Ford Explorer 4.0 SOHC Stock 2002 - 2005 Explorers 16
W Please help!!!!!!!!!!! Stock 2002 - 2005 Explorers 6
S BRAKE LIGHTS...PLEASE HELP!!!! Stock 2002 - 2005 Explorers 3
D 2002 ford explorer 4x4 please help Stock 2002 - 2005 Explorers 1
G I need some help with a Central Security Module question, please. Stock 2002 - 2005 Explorers 5
K Headlight will not turn on - Please Help Stock 2002 - 2005 Explorers 3
G Need Help With Door Lock Please. Stock 2002 - 2005 Explorers 1
O please help, wobble back and forth, have new control arms what else!? Stock 2002 - 2005 Explorers 6
C Help a disabled Marine Corp veteran out please Stock 2002 - 2005 Explorers 3
D Please help me identify source of brake noise Stock 2002 - 2005 Explorers 8
S Starter Problems...please help fellas!!! Stock 2002 - 2005 Explorers 2
L Please help!!!! Stock 2002 - 2005 Explorers 3
R Silly question please help out the newbie! Stock 2002 - 2005 Explorers 3
I Please help 2002 Explorer 4.0 Stock 2002 - 2005 Explorers 0
S Theft light blinking, wont start. Help please. Stock 2002 - 2005 Explorers 1
C Help with noise please Stock 2002 - 2005 Explorers 0
S clunking in and out of 4x4 mode. Please help? Stock 2002 - 2005 Explorers 1
S Need some help again please Stock 2002 - 2005 Explorers 4
Similar threads
