MichaelT1984
- November 22, 2013
- Needles, CA
- 2006 explorer 5r55w 2WD
My two wheel drive 2006 explorer with the 5r55w or 5r55s transmission is stuck in what it think is fifth gear. It's been having shifting problems including a delay when going into reverse, sometimes slamming into reverse, and now revving or downshifting when cruising at around 50mph. It has over 300,000 miles. it used to be a taxi so I'm not sure if it has the original trans. either way went to autozone and they pulled a P0735 code meaning incorrect 5th gear ratio. I've researched this problem and found two possible culprits, the solenoid block and/or servo pin bore wear. will shift into reverse but not into 1, 2, or 3rd. Only drives when put into drive and is stuck in fifth. Looking for some pro advice on what else might be the problem.
