HELP! SAS Power steering issue | Ford Explorer Forums - Serious Explorations
Mutineer
Location
Ardmore, AL
Ardmore, AL
1997 Explorer XLT 4X4
Callsign
FLOYD
OK so heres what Im doing, and I want to keep this a separate thread from my SAS thread, in case someone else has this issue...
I am using the following:
Stock PS pump
Steering gear from 1978 Ford F250 H.D. 2WD
Stock PS Pressure Hose
3/8" High pressure rubber hose for return(due to lack of correct PS hoses for this combo)
OK heres the deal.
The Steering gear has 2 fittings, a 3/8" and a 1/2".
The Pressure hose fits perfectly in the 1/2" fitting (thread depth and everythng) and I have a nipple installed in the 3/8" fitting for the return hose.
Heres what happened:
cranked truck and everything was fine untill I touched the steering wheel, then the wheels jerked over to the right all the way and the pressure line blew out it's side and sprayed my whole driveway with PS fluid.
After cleanup, I was able to figure out where it blew.
My camera was soaked with fluid so I was not able to get pictures, should be able to get some tonight.
Has anyone seen this before?
Could it be that I hooked it up backwards?
Im to the point where I think I need to ask before I move forward.
Yep, you installed the lines backwards. I've seen it happen before.
Sweet. I was hoping someone would say that. Thats what I was thinking but Ive never seen it before so it threw me for a loop...lol
Question...
what kind of rubber line would I need to handle the pressure on the pressure side?
I cant find a pre-fab hose that fits both the pump and the gearbox.
Can I use nipples made from the other line-ends and some good hose clamps to fab up my own? Ive never tried this before cuz I dont think it will work...
I really dont feel like cleaning my driveway again... :rolleyes:
Your help is very much appreciated.
ROFLOL with tears in my eyes! That happened to us years ago on our 69 mustang racer. Except when we fired the engine over the steering wheel and all connected componets thrashed voilently from side to side until we shut her down. An eye opening experience to say the least! Almost lost both thumbs that time.
Yes it was en eye opening and a shoprag consuming experience...lol
I am guessing that if I put it on right it'll work, provided there is no damage.
Try # 2 coming Monday night...:rolleyes:
