When I use a jumper wire across the clutch cycling switch, I get good pressure readings and cold air. But when the cycling switch is attached, the compressor is kicking off at too high a pressure, the cycling rate is fast, and the air never gets very cold. I changed switches, but it is still kicking off, like before, at around 35 pounds. (The manual says it should be in the twenties). Can somebody give me a hint of what is going on? By the way, this only started this Spring. And I have evacuated the system, drawn a vacuum, etc. and recharged. Nothing seems to make a difference.
Any advice will be appreciated.
