HELP! Superlift driveshaft noise.... Driving me CrAzY!!!!!!!!! | Ford Explorer - Ford Ranger Forums - Serious Explorations
Jamieh560
Wilmington, NC
'97 Sport
I notice a sqealing noice as I drive my explorer down the road... It has 4" superlift and I got the superlift driveshaft like 6 monthes ago... I pulled for the road and floored it and held brake -----> no noise with rear wheels spinning... so I put on lift the put in 4wd and the sqealing noise is coming from the dual cardan joint... Anyone else had this this problem... Its really bad it sounds like metal on metal brakes... No grease fittings would should I do? Thanks Jamie
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
Had a similar issues with a Superlift driveshaft on a lifted SIlverado. There actually were grease fiittings but they are hard to get to. Remove it and take it to a driveline shop where they can either replace the stuff or maybe just grease it up for you.
-Drew
