HELP! Trans. Issues, recently rebuilt, shop cant figure it out.
Mustangman66
Tolland CT
2003 4dr Explorer, v6
So heres my 2003 ford explorer 4 door. It has 125k on the clock. the transmission failed (Blinking O/D light of death) a shop with a good reputation rebuilt the transmission.
and then this:
http://youtu.be/9Lv1HBiNf6U
Most obvious begins at 7:10. Good example at 3:40, other incidents happen at 0:20, 0:58 1:42 3:09 4:15 4:55 6:15
Sometimes when transmission shifts, It wont engage the next gear immeadiatly, allowing the engine to "Rev Up" briefly. Sometimes the transmission wont engage the next gear for several seconds.
In my honest opinion the transmission is not preforming anywhere near as well as before you rebuilt it. It shifts differently. the gear lever does not go into drive when you put it in drive, you have to give it a little tap to get it into drive. the whole car sounds diffrent, and not in a good way, idle noise is MUCH louder then stock.
Does Anybody have any idea why my transmission is doing this?
Please Help!
chopperb
Chicago
04 explorer
Did the trans shop replace the valve body? How about the solenoid pack? If they did I bet they are not new? The problems you are having are pointing to the solenoid pack,possibly the valve body.
LJBex
Tobyhanna, Pennsylvania
1996 Explorer 5.0 AWD
I agree. have seen this a few times in the past couple of months. it was dirt in the valve body or a solenoid pack that has fixed the problem. a good scanner should pick up on this problem.
I work in a transmission shop and we work on a lot of these.
D 2002 trans issues... need help asap Stock 2002 - 2005 Explorers 1
M 2002 Mounty trans issues..(help) Stock 2002 - 2005 Explorers 4
F Trans help needed. Stock 2002 - 2005 Explorers 1
0 02 Limited 4.6l 4x4 Trans - Pls Help Stock 2002 - 2005 Explorers 6
N Help with trans Stock 2002 - 2005 Explorers 17
M '02 AWD Mountaineer-trans started hard shifting - help Stock 2002 - 2005 Explorers 6
M 04 Explore 4.0 Trans Help Stock 2002 - 2005 Explorers 6
S Need help in the NJ/PA/DE area, trans + hub. Stock 2002 - 2005 Explorers 7
P Tried replacing trans input shaft sensor p0715 old sensor broke off. Help Stock 2002 - 2005 Explorers 6
R Trans ID HELP!!! Stock 2002 - 2005 Explorers 8
S Help! - Leaking warm water near trans (Picture of source) Stock 2002 - 2005 Explorers 4
M Help! Stumped by Trans / Transfer problem Stock 2002 - 2005 Explorers 4
B Need Help: How do I get the SERVO BORE retaining snap rings out on the 5R55 trans? Stock 2002 - 2005 Explorers 10
B Trans fluid and filter change help Stock 2002 - 2005 Explorers 3
J Trans help? Tried Servos - anything else worth a try? Stock 2002 - 2005 Explorers 9
B ford explorer trans problem please help me Stock 2002 - 2005 Explorers 1
D Can a trans flush help a problematic trans on '05 Ford Explorer? Stock 2002 - 2005 Explorers 2
B Need help Stock 2002 - 2005 Explorers 2
W Needing some help Stock 2002 - 2005 Explorers 0
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
H need a little help please Stock 2002 - 2005 Explorers 1
W Help Misfire Stock 2002 - 2005 Explorers 1
W Age old timming help Stock 2002 - 2005 Explorers 7
O P0152 Code - Help!!! Stock 2002 - 2005 Explorers 4
H Serious Misfire, Please help Stock 2002 - 2005 Explorers 2
J Body Work Help Stock 2002 - 2005 Explorers 4
S Transmission Help Stock 2002 - 2005 Explorers 2
K Help me Stock 2002 - 2005 Explorers 5
B Help Selecting a OBD2 scanner Stock 2002 - 2005 Explorers 26
L Overheated Explorer, need help or engine Stock 2002 - 2005 Explorers 0
D Help! Tranny hung in 4th gear. Stock 2002 - 2005 Explorers 2
R 4x4 High Light Flash need Help Stock 2002 - 2005 Explorers 0
P Help with part#. 04 XLT 4.0 SOHC Stock 2002 - 2005 Explorers 6
A 2004 XLS low beams not working - please help Stock 2002 - 2005 Explorers 4
M Rear Sway Bar End link Replacement help Stock 2002 - 2005 Explorers 3
A Help! Fuel pump. Stock 2002 - 2005 Explorers 0
H 2002 ex sport 2 door rocker panel help. Stock 2002 - 2005 Explorers 2
H Need help with parents 02 explorer(rear axle?) Stock 2002 - 2005 Explorers 6
S Need help with wiring Stock 2002 - 2005 Explorers 0
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
A HELP! 2005 Ford Explorer Fuel Pump ???? Stock 2002 - 2005 Explorers 15
M Problem starting after changing valve cover gasket. Please Help Stock 2002 - 2005 Explorers 4
I I need help with a power drain on my battery Stock 2002 - 2005 Explorers 1
M Please help with this noise also smoke and oil Stock 2002 - 2005 Explorers 7
A Help!! Control arm /end link bushing failure Stock 2002 - 2005 Explorers 12
S Help with a random misfires problem P0300, P0303, P0304, P0316 Stock 2002 - 2005 Explorers 3
R Help with Sonnax Servo replacements... Stock 2002 - 2005 Explorers 7
P '05 XLT V6, P0303 & no compression -- head gasket? valve? piston?-- pls help diagnose (video) Stock 2002 - 2005 Explorers 10
B Timing chain problems pls help Stock 2002 - 2005 Explorers 1
G '05 Explorer V8/5R55S - metallic SHHHH noise on acceleration, source help please Stock 2002 - 2005 Explorers 0
Similar threads
