Help- V8 Conversion question | Ford Explorer - Ford Ranger Forums - Serious Explorations
Here is what I am facing in my V8 conversion:
The V8 engine and engine wiring harness I will be getting is from a 1992 EFI 5.0L H.O. The tranny I will be using is a 1986 AOD automatic. Will I run in to problems when trying to hook up a 1986 tranny that is not computer controlled to a 1992 EFI wiring harness? Are the AOD trannys that came in 1992 computer Controlled??? Is there a computer controlled torque converter lock-up connection in the 1992 wiring harness, if so, how do I make this work with a 86 AOD??
Thanks for your input.
Al
asp84@earthlink.net
Gofast
Moderator Emeritus
Moderator Emeritus
McKinney, TX
76 Bronco
Should not be a problem. I'm doing the same thing.
The computer just send signals on RPM and tells the tranny when to shift. If you have a "Non-Computer" tranny leave the computer connections off, it want care.
Good luck and enjoy.
Kris Guilbeaux
Elite Demon Secretary
Staff member
Moderator
Austin,Tx
92 Nav, 99 Mounty, 98 Ex
I dont think any of the AOD were computer controlled. From what I under stand in the Repair Manual for our 95 Mustang the transmission was not computer controlled till 1996 when ford went to the 4.6L V-8.
Gofast
Moderator Emeritus
Moderator Emeritus
McKinney, TX
76 Bronco
There was or is...an AOD-E. The tranny shop asked me if this was what I wanted, but I said no. I need to check it may be mentioned in my Advance Adapters catalog. I'll double check when I get back in town. I do know that the later model 4.6 mustangs used a non AOD tranny, but thought the 94 & 95 used the hybrid AODE?
Kris Guilbeaux
Staff member
Moderator
Austin,Tx
this is the Reason I want a Manual Tranny. :rolleyes:
RFR2212
Typing Police
In the mug by Chitown
95 JEEP Wrangler
thank goodness Kris! Yah wiring sucks...Bottom line.
Pete
asp84
Tempe, Arizona
1998 V8 AWD Mounty
Gofast,
What type of combination engine and tranny are you using? just interested.
Gofast
Moderator Emeritus
Moderator Emeritus
McKinney, TX
76 Bronco
Gofasts combo
I'm using a 93 302, bored .30 over built for torque. I have a custom built AOD backing it up.
The only wiring I have is for Nuetral Safty Switch and revers lights. I runs through a small harness from the tranny to main harness.
Everything else works manually on this set-up. 1st and 2nd gear lock up the torque converter so very little heat is generated. 4th gear is 33% overdrive so I will tach about 2100 RPM at 70 Mph with 5.13 gears and 35" tires.
Have fun!
fordkrazy
Plantation FL
96 xlt 4x2
the aod-e came out in 87 on the crown vics but not the trucks and stangs and only controlled lockup instead of a vacum line. there was an xod-e that was fully controlled by the computer but im not sure what models they were in. i think that is what they use with the 4.6 in all the cars
