TFMoussa
- December 15, 2009
- Houston, TX
- 2003 XLT
Hi guys, I'm trying to tackle the infamous whining sound out of the rear differential in these explorers. I've never changed differential fluid, but I've done a lot of reading and the concept seems pretty easy.
Now the trouble I'm running into is that all the info I'm finding is for the previous generation explorers. I have a 2003 XLT (non LSD), and it looks like the differential set up is entirely different. It's not very accessible w/ part of the frame running right in front of it.
Secondly, I can't seem to tell if there is really a cover on it or not. It looks like the side that should be the cover also has arms that attach the differential to the frame.
Does this mean that in order to take off the cover, I would have to take off the 2 screws which are attaching it to the frame? And if I do this and take off the cover, then should I be worried about my differential falling to the ground and instead place a jack underneath to hold it up?
I opened the fill plug yesterday just to ensure it was loose enough to open once the cover is off, and some overflow fluid came out. I think it has so much metal shaving that it looks like glitter = / Hopefully adding some Valvoline 85W-140 w/ some antislip will help keep it in good shape and quiet down the sound.
