Help - Weathertech Mudflaps
sslinn
2015 Explorer XLT
I ordered a bug deflector and mudflaps for my new 2015 Explorer from Weathertech and they arrived today. The bug deflector was fairly easy to install, but the mudflaps are a different story.
I am on step 3 of the instructions and the two screws just keep spinning when I try to remove them. Any tips?
Thanks in advance for any help you can provide.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
ntex
Alvarado,Texas
2010 Explorer Eddie Bower
That plastic crap again, you'll need to get some pressure from behind the plastic screw, a putty knife blade might help,and either put pressure on the blind end of the screw or try to lift under the screw head while turning counter clockwise.
Professorfingers
Russellville, AR
2016 Ford Ex Platinum
Another option is to use pliers, to put the screw under tension, like you're trying to pull it out, while turning the screw. Just don't try and "force" it out-you might break the screw.
sslinn
2015 Explorer XLT
Thanks for the responses. I took another try at them and didn't want to be to forceful. No success. I will likely pay a body shop to install them.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Are these the plastic screws that go into the plastic holding like the push pin type holder? If so do not apply pressure against it when trying to unscrew it. Doing so just defeats the purpose of unscrewing it (your pushing it right back in). Even if unscrewing it "lightly" doesn't work take a flat blade screw driver and push it between the "washer" part of the screw holder and the vehicle and twist the flat blade screw driver slightly to put pressure on the "washer" so the screw unscrews while you take it out.
sslinn
2015 Explorer XLT
Body shop got them off. I guess I could have been more forceful. Thanks for the help guys.
krlseidl
2016 Explorer XLT
Weathertech Mud Flaps
I just went through the same thing. I am going to try and find some longer replacement screws to install in place of the factory ones. There is not much "bite" there after you install the mud flaps.
sslinn
2015 Explorer XLT
Yeah there is one I want to replace. Haven't quite had the time to find them online so please let me know if you do or the part number. I had am issue because I assume the rear and front rivets / screws were the same. They are not.
Smeeagain
Location
NYC
2017 EX Platinum
New question on an old thread.
I just received my mudflaps, and I'm wondering what size socket, box wrench, and allen wrench I need? I really don't feel like carrying the whole toolbox down to the vehicle (live in an apt building) when I can just take what I need to get the job done.
Also, can I use a trim tool to remove the fasteners, or is using the screw the best option?
Thanks for the help.
O New and needs help Stock 2011 - 2019 Ford Explorer Discussion 2
G need help with front assist parking camera Stock 2011 - 2019 Ford Explorer Discussion 1
N Help with Tire Size for Explorer Sport 2014 Stock 2011 - 2019 Ford Explorer Discussion 8
A Newbie in need of help!!!! Stock 2011 - 2019 Ford Explorer Discussion 3
B Moonroof Help Stock 2011 - 2019 Ford Explorer Discussion 1
M Rear Calipers - Help Stock 2011 - 2019 Ford Explorer Discussion 5
T Weird chirping noise PLEASE HELP! Stock 2011 - 2019 Ford Explorer Discussion 17
W 2013 explorer need help with horn disable Stock 2011 - 2019 Ford Explorer Discussion 1
L Help, what is this?? Stock 2011 - 2019 Ford Explorer Discussion 3
E New Member Help Stock 2011 - 2019 Ford Explorer Discussion 11
G Any Help Appreciated ! 2011 Explorer cylinder misfire 4/5/6 Stock 2011 - 2019 Ford Explorer Discussion 4
R Need help with identifying connector with missing wires Stock 2011 - 2019 Ford Explorer Discussion 3
R Help finding correct part number....... (Heated seat) Stock 2011 - 2019 Ford Explorer Discussion 5
E Forscan Help Stock 2011 - 2019 Ford Explorer Discussion 5
A HELP.. Wont start, has a lot of errors (Resolved) Stock 2011 - 2019 Ford Explorer Discussion 21
C Tapping Noise Help Needed Stock 2011 - 2019 Ford Explorer Discussion 0
Terryhan05 Looking for help in Hampton Roads with Forscan! Stock 2011 - 2019 Ford Explorer Discussion 2
M 2011 Explorer Remote start fob alarm pressed and cannot reset - help Stock 2011 - 2019 Ford Explorer Discussion 4
T Need Help 2012 Explorer Heavy Misfires / Highway Speed Stock 2011 - 2019 Ford Explorer Discussion 2
T Newbie here needing help ** problem identified Stock 2011 - 2019 Ford Explorer Discussion 10
R Help finding antenna connection Stock 2011 - 2019 Ford Explorer Discussion 1
T 2017 Explorer Platinum PTU help needed Stock 2011 - 2019 Ford Explorer Discussion 0
K 2011 Banging noise in front, need help Stock 2011 - 2019 Ford Explorer Discussion 14
D Need professional help with transmission (6f55) Stock 2011 - 2019 Ford Explorer Discussion 6
M Help with removing second row seat Stock 2011 - 2019 Ford Explorer Discussion 1
K Help with starting issues!! Stock 2011 - 2019 Ford Explorer Discussion 7
C New Wheels Questions. HELP ME Stock 2011 - 2019 Ford Explorer Discussion 9
C Need help with OBD code P0430 Stock 2011 - 2019 Ford Explorer Discussion 12
S Heed Help... 2011 Explorer Limited will not start. Stock 2011 - 2019 Ford Explorer Discussion 8
G Lift gate moulding parts difference, please help! Stock 2011 - 2019 Ford Explorer Discussion 3
J Detail guys ruined matte finish with leather conditioner. Help! Stock 2011 - 2019 Ford Explorer Discussion 18
S 2014 Sport steering clunk help please Stock 2011 - 2019 Ford Explorer Discussion 10
W 2017 XLT Tail Light help. Stock 2011 - 2019 Ford Explorer Discussion 1
S Help Clearing Moonroof Drain Lines on '16 Explorer With Dead Motor Stock 2011 - 2019 Ford Explorer Discussion 26
G Part help - 2013 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 3
S Can you reset MyKey with only one key?! HELP! Stock 2011 - 2019 Ford Explorer Discussion 10
L Newbie Audio help Stock 2011 - 2019 Ford Explorer Discussion 1
B Temperature Control Module Swap Help Stock 2011 - 2019 Ford Explorer Discussion 0
H 2016 Ford Explorer Limited Speaker and Amp Upgrade - Help Sought Stock 2011 - 2019 Ford Explorer Discussion 1
H Help - 2016 Ford Explorer Limited - Won't Start Stock 2011 - 2019 Ford Explorer Discussion 3
M Need Help: How to remove the upper intercooler piping? Stock 2011 - 2019 Ford Explorer Discussion 2
R help me identify this loading area/liftgate trim piece I broke Stock 2011 - 2019 Ford Explorer Discussion 5
S Help! Window Tint Matches Outside But Not Inside Stock 2011 - 2019 Ford Explorer Discussion 20
S Help me decide on a color for a 2019 Sport Stock 2011 - 2019 Ford Explorer Discussion 22
E HELP PLEASE... think ECU stroked out!!! Stock 2011 - 2019 Ford Explorer Discussion 1
R Help metallic noise! 2011 Stock 2011 - 2019 Ford Explorer Discussion 1
K 2015 sport turbo replacement ... Help? Advice. Stock 2011 - 2019 Ford Explorer Discussion 9
D HVAC Vent Modes Not Working... HELP!!! Stock 2011 - 2019 Ford Explorer Discussion 1
M 2016 Explorer Front End Wiring/Plug Help Stock 2011 - 2019 Ford Explorer Discussion 3
O 2015 TPMS fault help needed Stock 2011 - 2019 Ford Explorer Discussion 13
Similar threads
