update,I had a lot going on at one time here. the rear diff has had a whine for a good while, so over this past weekend I replaced all the bearing associated with the rear diff., and reset the gears. I had a fairly good pattern on the face, I think, first time setting up gears. I did my homework, and feel fairly confident on the rear diff. Also I had a bad wheel bearing that I replaced. As for the DS, I put new U-joints in my original DS, and I still have a vibration. The vibration is noticeable from about 30mph on up, it does get worse the faster you go, up to about 90mph then it starts to smooth out. I did notice up and down play in the slip joint, a 1/16" or so, and a little little play at the transfer case flange(no fluid leak at seal). Unless I am just feeling the play in the slip joint, I have not checked the transfer case play with the DS off. So will a bad Slip joint make a vibration, and could the rear diff. be vibrating. There is no whined and after a hard run(90-100mph) down the interstate the rear diff. temp. is around 170-180deg. norm interstate drive rear diff. temp is at 140-150deg. vibration makes me crazy.lol
