Help with 1992 Explorer vacuum lines | Ford Explorer - Ford Ranger Forums - Serious Explorations
tlcisme35
1992 Ford Explorer
This morning while starting my 1992 explorer somewhere a vacuum line came off and my explorer will not shift out of 1st gear. I have checked the top side and can not find any lines off. Can anyone give me somewhere to look? Your help would be a great help.
barneyhyphen
Nashville, Tn
1999 Explorer EB 4.0 SOHC
Can you post a picture of the hose in question please.
BH
arco777
1994 Explorer 2dr 4x4
The only vac line affecting shifting is your vacuum modulator line. Without the vac mod hooked up you will get 3000rpm shifts. The modulator is located on the passenger side of the transmission housing; you should be able to follow the line from there. There's an access panel in the floor under the carpet as well that will let you get at the modulator.
