ixbigybxi
- June 24, 2004
- Logan,Utah
- 95' Ford Explorer Limited
Hi,
I'm Brandon a new member to this forum. I have me a 95' ford exlporer limited. I took out the adjuster bolts on my torsion bars to lower my front end a little bit. I did not do anything to the back yet, if I do at all.
But ever since I lowered the front end my ARC (Adjustable Ride Control) is always try to level, so the compressor is going most of the time. I tried resetting my ECU to see if that helped and it didn't.
Can I turn my air ride system off by that switch in the back and drive like that with out hurtting anything? Or is there any thing else that can be done? I am thinking about lowering the rear 1.5"-2" (MAYBE) If someone could help me out that would be great?
Thanks,
Brandon
Thanks,
Brandon
