sevans17
- June 13, 2011
- NJ
- 2011 Limited
Smart ford owners, tinkers and mechanics;
Looking for assistance, help and advice! We have a 2004 Ford Explorer 4.0L SOHC v6 with about 71k miles on it and misfire problem that I haven't been able to get to the bottom of yet. I have a scanner with live data capabilities if there are other things I should check with that hopefully pinpoint the problem so I can fix it. Here's what I know and the things I've tried / changed so far.
Symptoms:
The only diagnostic codes it gives are P0300, P0303, P0304, P0316
Parts replaced so far:
Symptoms:
- Random misfires
- often shortly after startup
- regularly inducible between 43 - 48 MPH with RPMs in the 1200 - 2500 range.
- other more random / inconsistent times
- Occasionally slow to respond to accelerator being pressed
- Spark Plugs of cylinder 3 and cylinder 4
- Ignition Coil Pack
- Check diagnostic codes and read about each
- Visual inspection of hoses, air box etc no signs of splits, cracks, holes etc
- Visual inspection of spark plug wires / boots
- Mist spark plug wires / boots with water looking for indicators of damage / short
