help with flexplate spacer | Ford Explorer - Ford Ranger Forums - Serious Explorations
hatched91
godfrey, Illinois
1997 sport ohv 5spd
Okay, i sold my friend my 1997 explorer 4.0 ohv to put in his 91 explorer. The 97 motor came with a 5spd. It has an 8 bolt crankshaft and the 91 had a 6 bolt. my friend is trying to put the 97 into the 91 which has an automatic trans. he pulled an 8 bolt flexplate from the junkyard and swears there was no spacer, but it seems like there needs to be a spacer for it. none of the local auto part stores show one. Does anyone know if the 96 and up has a flexplate spacer? if so, does it need to come from an OHV and no a sohc? is the OHV flexplate different from the SOHC?
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Glacier991
EF Tranny Guru
Moderator Emeritus
Sacramento, CA 95827
1992 XLT
Let me understand. He is taking a 97 5 speed manual tranny and swapping it into a 91 that previously had an automatic ?
hatched91
godfrey, Illinois
1997 sport ohv 5spd
no sorry, i guess i could've wrote the story a little more clearly:D my friend is trying to put a 4.0 ohv from a 97sport into his 91 explorer. the 91 explorer block had a 6 bolt crankshaft and the 97 has an 8 bolt crankshaft. the 97 came with a flywheel, therefore we did not have the flexplate. he went and pulled a flexplate from the junkyard off of an 8 bolt 4.0. we are trying to figure out if there is supposed to be a spacer on the ohv and if the flexplates differ between ohv and sohc.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Glacier991
EF Tranny Guru
Moderator Emeritus
1992 XLT
I was waiting to understand before I pointed out the difference between a flywheel and a flexplate.
There is a spacer. BB has steered you to a place you can obtain it.
hatched91
godfrey, Illinois
1997 sport ohv 5spd
thanks for the help guys. i found it and its super cheap!
rookieshooter
Moderator Emeritus
Martinsburg WV
84 BII "Li'l Samson"
I do not know about your application, but on a 302 they have a different spacers for different toothed flexplates. Even though they both bolt up perfectly. It's in the bolt holes for the starter that things get screwed up.
