Help with fog light installation | Ford Explorer - Ford Ranger Forums - Serious Explorations
I have a problem with installing the wire for turning on my fog lights. I mounted the lights on to my bumper. But I don't know what to do with the wire that goes to the switch. Should I drill a hole through the firewall? Or should I put it through the driverside fender go through the rubber where all the door wires go? Please help. Thanks
bdogg23
Scottsdale, AZ
1993 XLT 4DR 2WD
theres a plug thingy near the brake pedal on the firewall, you can just poke it through there. if i had my x right now i would take a pic.
Bill Kemp
Elite Moderator Emeritus
Moderator Emeritus
Greenville, MI
98 Mountaineer 5.0 AWD
Follow the hood release cable to where it goes through the firewall. Lots of room around there. I poke a clothes hanger through the hole, tape the wires on it and pull it back into the cabin.
AintNoFantasy
Lucerne, Maine
91 Eddie Bauer
exactly, just follow where every other wire goes through, no need to make a new one.
BIG COUNTRY
EIELSON AFB, ALASKA
1998 XLS 4x4
RIGHT UNDER THE BRAKE MASTER CYLINDER AND UNDERNEATHE THE OTHER CRAP THERE IS A RUBBER GROMMET...YOU CAN SEE IT ON THE OTHER SIDE INSIDE THE TRUCK...RIGHT UNDER THE BRAKE PEDAL...THAT WOULD BE YOUR BEST PLACE TO START...
sorry 'bout the caps...forgot about it...
AlaskanJack
Elite Cabin-Fever Captain
Centralia, Washington
91 , 93 & 01 Sports
Yep lots of places. My offroad lights have been run into a wire loom that goes to the firewall and then through an empty grommet.
