kworonowski
- December 9, 2011
- Denver, Co
- 2008 Explorer limited v8
Well i thought i had it figured out as bad tensioner seeing as i could push on the belt and move the tensioner with almost no pressure. Replaced that and still have clicking noise from front of engine. I listened to water pump condensor alt and pulleys. no obvious source of the noise. It sounds like the fans are loose but the bolts were tight. So i guess water pump should be next on the list? no chripping or squeaking and balancer looks smooth (no wobble) when i look at it. Any other ideas before i start treating it like the dealership and just throw parts at it? Ive had no issues with it for the last 4 years cept tires, brakes and fluid flushes/changes. No loss of power or any odd smells. Any ideas are appreciated.
what happens when water pump goes bye bye?
what happens when ac compressor goess bye bye?
this is my only ride to work and what not i'd rather not blow up to or from work (or anywhere if possible)
