Help With Relay For Lights | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Okay I'm going to be install some 4 55watt lights and I was going to put 2 on one switch and relay and 2 on another switch and relay. Now I have two relays but one of them has 5 pins on it, two of the pins are 87 so am I able to use this relay? And if I can how would I wire it with it having two 87s?
97Mounty97
Port Huron, MI
2004 Ford Explorer
There should be an 87, and 87a pin. Use 87.
Okay thank you and would I just use electrical tape and tape off the 87? Or just leave it alone?
97Mounty97
Port Huron, MI
2004 Ford Explorer
I've just left it alone on previous setups and it was fine.
If for some reason you want to have both relays but only one switch to turn all 4 lights on or off at once, let me know and I'll dig up the schematic for that.
Okay thank you
and I'm just going to use 2 relays and 2 switches to keep it easier but thanks for the offer
