b.voorhees
- March 12, 2011
- NJ
- 1999 5.0 Limited
I am currently attempting to do a fluid change on my 4r70w transmission. There were no problems dropping the pan. I am now attempting to drain the torque converter and I removed the drain plug from the bell housing and no fluid came out, the area inside seems bone dry. I have done some research and and this drain plug is supposed to give you access to another drain plug. However I can not see another drain plug. So now I am completely lost, please help.
