SuperSwede
- February 11, 2006
- Småhåla,skogen
I´ve had the car for a year soon. Lately it has become sluggish and “slow”. Fuel consumption has gone up through the roof, and the car seems to lack power. From a standstil on gravel it hard to get it to spin.. it just barely do and then just eases of..
My first thought was that the transmission was the problem.. I changed the oilfilter and flushed oil out via the radiator. The old oil was a sad sight.. tar black and smelly. Not a minute to late.
Not much changed.. the gears go in and out quite fine, the OD works and the rev are below 2000rpms at 90km/h. One thing I´ve notised is that it downshifts for every little reason.. a slight climb, barely noticeable can be enough. Pretty much so that if I have some wind in my back it goes just fine.. turn around and go against the wind and it downshifts !! Turns me ..
A kickdown at 90km/h for a overtake just produces a lot of noice an less action.. sure it accelerate, but not as I would expect, or it did a while ago..
Sluggish is the key word..
Some guy told me to do a test: with a warm engine , foot on the brake hard and then punch the accelerator and see if it goes over 2800rpm´s.
No it doesn´t, It cuts out at that rpm.
According to that guy that indicates that the transmission is just fine.
Perhaps I should look for the reason elsewere?
Please help me troubleshoot this one.. it gives me a great headache..
Airfilter and plugs are new..
Thanks.
Thanks.
