Daisywheels
- July 1, 2014
- 1999 XLT XP SOHC V6
Hi everyone - I believe I have finally found the cause of my vacuum leak which I am assuming is giving me the rough idle, and misfire codes. I checked the seating of the upper intake manifold to the lower intake with a VERY bright flashlight, and sure enough, I could see part of the gaskets. I assume that should not be with a properly mounted upper manifold?
1) I just tried to reseat the upper manifold to the lower, and it is not seating properly. I followed Haynes, and several guides here, and I just can't figure out why it won't seat properly. My best guess is the EGR tube is not allowing the upper manifold to seat right. Has anyone had issues with this?
2) Also using the flashlight, I discovered a possible hole in the air intake valve on cylinder. Can anyone point me to a thread on how to replace these air intake valves? Having trouble locating directions. The valve is only like 5 bucks at rock auto and look like this:
http://www.rockauto.com/catalog/moreinfo.php?pk=5579595&cc=1354542&jnid=564&jpid=0
3) I am going to pull an all nighter and see if I can get the lower manifold out and mate it up with the upper off the car just to make sure there is no warping. I'm doubting that - more leaning towards the EGR tube.
4) Any other ideas or suggestions would be greatly appreciated! Thanks! - DW
