Help with what gears to run
Bremerton WA
1989 Bronco II
Ok, I need some advice here.
Im building a 88 Bronco II, still has the 2.9 with 5 speed. Front is going to be an EB D44 and the rear is allready Sploder 8.8. My plans are in the nature of 36" swampers. Now I still drive this about 10 miles each way to work, nothing major. What would you recommend for gears in this?
Kyle0614
Greenville, NC
'95 XLT
I'd go with 4.88's or higher for that kinda tire size at least i'm going to run 4.88's in my rear when I go too 35's ...:p will that 2.9 push 36's? if so mad props
Bremerton WA
1989 Bronco II
lol... I dont really know, anyone ever run 36's on a 2.9?
Bremerton WA
1989 Bronco II
I know I can run the LTB 34's but I wish they were just a little wider, I may have to go that route anyway to play it safe
Bremerton WA
1989 Bronco II
so you think that little ol 2.9 can push a set of 36's? Or should I go smaller to stay safe
FROADER
Moderator
Staff member
Moderator
Huntington Beach, CA
1997 XLT
If you go smaller than 36s you don't need to swap axles. :D
Stay with the 36s and get 5.13s. the 2.9 will push anything if geared right.
Yota guys with 22Rs are pushing 44s...
Bremerton WA
1989 Bronco II
I like the way you think Froader. I wanted the 36's but there were some other members elsewhere trying to convince me otherwise. I have thought about the Yota boys too..... 22R on 44's with no problems. I was thinking that if I stayed 36's I would need the 4.88's or 5.13's, looks like the 5.13's it is
MidnightRebel07 Looking for best place to buy 4.88 gears and other parts for my SAS. Need help... Offroad Drivelines 9
SuRrEaLNJ Need help finding some gears Offroad Drivelines 1
N anyone running 4.56 gears ? i need help ! Offroad Drivelines 5
D what gears?????help!!! Offroad Drivelines 6
R Need help-Ring & Pinion gears - 3.73 or 4.10 Offroad Drivelines 9
D Ford 9" Question/ Tone ring/ VSS... HELP? lol Offroad Drivelines 1
gmanpaint Wanted If you have done the front c-clip eliminator Mod, I need your help please. Offroad Drivelines 7
B Help Me Choose Offroad Drivelines 2
T Locker Help Offroad Drivelines 10
0 Coming soon Dana 44 SAS Questions...Help Offroad Drivelines 3
D Help! I found a Dana 44 and some parts... Offroad Drivelines 8
R Help: LSD spider gear tension stuck Offroad Drivelines 15
nssj2 79 Dana 44 ball joint help Offroad Drivelines 4
P D35 SWAP INFO or help? Offroad Drivelines 2
D Help with Front Drive Shaft Offroad Drivelines 17
S 91 chopped sas help Offroad Drivelines 3
B need help asap Offroad Drivelines 2
crazyflights Front Dana 60 ??? Please help, wheel sizes Offroad Drivelines 14
K 8.8 Re-gear (help with pattern) Offroad Drivelines 5
D i need help Offroad Drivelines 4
R Need Help!! Ranger 4.0L Manual To auto problem.. Offroad Drivelines 9
dkchrist Manual t-case Swap Help Tailhousing issues Offroad Drivelines 0
Dannyboy 9" Disc conversion help! Offroad Drivelines 4
nssj2 Aussie locker help asap Offroad Drivelines 9
D Help with SAS Offroad Drivelines 19
9 SAS with Jeep D30... Help? Offroad Drivelines 3
S front drive shaft help 911 Offroad Drivelines 1
A Help Confused Offroad Drivelines 0
E gear to wheel help Offroad Drivelines 6
9 Help fixing my 5 ton Rockwells Offroad Drivelines 4
B Need Help Asap Front Axle Keeps Popping Out Offroad Drivelines 4
S Help needed ! Differences in axle housings Offroad Drivelines 15
F 92-8.8 mods?need help Offroad Drivelines 4
J Need help to identify this traction aide Offroad Drivelines 10
SuRrEaLNJ 94 squawk list... need some help Offroad Drivelines 6
9 97 sport help Offroad Drivelines 0
B drive shaft HELP Offroad Drivelines 1
E help, my truck wants a tremec Offroad Drivelines 0
3 dana 44 help... PLEASE Offroad Drivelines 8
D Found axles, need help! Offroad Drivelines 7
M Need help: Regearing Offroad Drivelines 17
4 HELP! 1.75" wheels spacers on ttb? Offroad Drivelines 14
B dana44 rebuild help me!!! Offroad Drivelines 12
B locker help Offroad Drivelines 4
F driveshaft help/questions Offroad Drivelines 3
D Axle / Wheel bearing help please Offroad Drivelines 3
D Help with 8.8 Locker Offroad Drivelines 13
rookieshooter Axel truss, need your help? Offroad Drivelines 3
B axles help me Offroad Drivelines 5
4 help:sas or ttb? Offroad Drivelines 78
Similar threads
