Help with wiring harness swap and PCM
Tommyboy79
W,va
2001 ford explorer
Ok. I have 2003 PCM from a Ford Ranger 4.0 and I also have a 2001 Ford Explorer 4.0 motor wiring harness.
I have rewire the 2001 wiring harness to the 2003 PCM. The trouble am having is one wire to the PCM it is
__________________________________________________ _
82 ---------- 1017 (BK/WH) ------------ Check cap indicator lamp
Then it runs to the C110 black plug to the motor wiring harness to.
40 ------- 911 (WH/LG)
41 ------- 1017 (BK/WH) ----------- Check cap indicator lamp
42 ----------- J37
But the 2001 Ford Explorer wiring harness don’t have that wire and the C110 Plug for the motor wiring harness.
Don’t have that wire. So does have this instead.
40 -------------- 911 (WH/LG)
__________________________________________________ ___________
41 ------------ 904 (LG/RD) ---------------- "Generator/Battery indicator, control"
----- OR ----
1017 (BK/WH)
__________________________________________________ ____________
42 ---------------- 36 (YE/WH) ------ "1 Voltage supplied at all times (overload protected)"
__________________________________________________ ____________________
And I have C102a or b plug to the Generator
1 ---------------- 36 (YE/WH) ------ "1 Voltage supplied at all times (overload protected)"
2 -------------------------- Not Used
3 --------------------------------- 904 (LG/RD) ---------------- "Generator/Battery indicator, control"
__________________________________________________ ________________________
I hope you all can umderstand what i am trying to tell you.So there is my problem am having what should
I do for the ‘1017 (BK/WH) wire’ for the ‘Check cap indicator lamp’ ?
Like I said the 2001 Ford Explorer wiring harness doesn’t have Check cap indicator lamp wire in it at all…
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
2000 and 2001 explorers should both have that wire
Not clear what you are asking
Tommyboy79
W,va
2001 ford explorer
I'm working with a 2003 pcm to a 2001 wiring harness. the 2003 pcm call for a wire that the 2001 wiring harness does not have.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Then ignore it, it is simply a feed to the instrument cluster for the "check fuel cap" light
basically if the computer sees the fuel tank pressure is not where it is expecting it to be the PCM will tell you to check your fuel tank cap..........
Is this the ONLY wire the 2003 PCM is expecting that does not exist?
Why are you putting a 03 PCM into a 01 truck?
Tommyboy79
W,va
2001 ford explorer
Because I did a Maunal swap in the Explorer.
