Dash Riprock
- April 9, 2005
- LA, CA
- 95 Explorer XLT
Help..X stuck, ..tranny inop - Pictures added
I tried placing this in the 911 forum and it says I cant do it. If any Moderators see this, feel free to move it.
My 95 XLT was heading home from a camping trip and the tranny started to slip on the mountain hills. It seemed to downshift reluctantly and when it did there was little power increase. Finally, it started slipping everywhere and that was that. I currently have no gears at all, including reverse. If the truck is allowed to cool down considerably or is started while cold, it will engage Drive very slowly and creep but within 15-30 seconds will start to slip and refuse to budge.
I have to make a quick decision to allow this to go to repair or try to fix something myself. Ive read alot of posts on here about tranny problems and many end with a shrug and "oh well, 2k down the drain". Id like help narrowing this down to see if I can do it myself. I am an able mechanic so with the right tools, I should be able to do what is needed.
Some specifics. The fluid is at the correct level. It is semi-new. By that I mean that I changed it a few months ago, but did not do a complete flush (pan only + filter).
The tranny had problems recently( o/d light flash, shift flare, slow shifting -documented on this board elsewhere) that was caused by a radiator leak which allowed the tranny fluid to overheat. The partial tranny fluid change, and the fix to coolant leak (heater control valve) seemed to bring the tranny back.
My novice understanding of transmissions, (greatly helped by the posts of Glacier, Brain, and others - thanks) tells me this cant be a failure that cant be fixed. The tranny made no grinding, crunching noises, there was no lurching, surging or intermittant operation. If I am correct, the tranny consists of a Torque Converter which makes a fluid lock, if that fails or no fluid exists in the TC, I believe it would match my problem, no? I dont see it as being bands and valves, because my understanding is that these components affect certain gears, or combinations of gears. It seems unlikely that every one of them failed. How about the fluid pump? Is it possible that no fluid is getting to the TC?
Id appreciate any ideas or things to look for. If ive omitted any info, please ask.....Ill be here all week.... Thank you.
