Herculiner ? Should I put running Boards back on? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Hello. I am new to body work so please bear with my stupid question! I am having alot of rust pop up at the line where my running boards are. I would like to sand this rust off and put in some type of herculiner or something similiar. My question is this, after herculiner is on can running boards be reattached no problem? I know many people hate the running boards, but I am small and need them to stand on to buckle in a kid in the middle seatbelt. For me they do serve a purpose!! any info is helpful. also best sanding tips?
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
As long as you tape off the mounting holes/surfaces and dont get it in the threads of the bolts you should be alright.
MONMIX
I fix dents
Moderator Emeritus
Millersville , Maryland
2000 Explorer Sport
just know this herc WILL NOT stop rust
churd69
Michigan
07 Silverado Z71
Nor will it easily be removed from the hootus.
-Rich
WECALLHERDORA
michigan
1994 ltd
Is there something that will stop the rust or slow it down? Michigan winters are going to be the death of us!!
WECALLHERDORA
michigan
1994 ltd
I dont have to worry about that, as I dont have a Hootus!
churd69
Michigan
07 Silverado Z71
ah, so you discovered the hootus thread! I'm sure you can get something to stop the rust, i believe rustoleum makes a product, then just put the herculiner over that.
-Rich
Perry
Moderator Emeritus
Loveland Co.
1994 XLT
The other bad part about putting the hurc over the rust is it will hide it, but the rust will still grow.
As MONMIX has said, you can slow rust down some but it won't ever go away.
