Hey Guys. I am building an extreme budget turbo Mountaineer. It is an early 97 5.0. Before I get into details I know the parts I am using are cheap, but I have done a lot of reading over on theturboforums.com and have gotten some of the best cheap parts if that makes any sense lol. So I have a few questions. I need to know what size wastegate to run. I am going to be running the gt45 chinese turbo and only want to make around 10 psi. I was thinking a 50mm wastegate should work good, but im not sure. Also The turbo is going to be mounted pretty far back under the truck so I am assuming that I will have to run a blow thru maf. What maf should I be looking for? ALso (this is just an off the wall question so please just bear with me) Is there anyway I could run a draw thru setup if I extend the maf harness or is it too far away from the engine to work properly? To put this build into perspective I bought the truck for $800 and put probobly about $400 into reapirs to get it in good shape. I have spent $370 for the turbo and all flanges and a 14 foot section of nitrous line to use as an oil feed line. This is truly a budget build and I am not expecting it to last. I apreciate any input. I will be documenting the build in this thread with pictures along the way. Thanks
