Here's the BEEF - HD yoke for 8.8"! | Ford Explorer - Ford Ranger Forums - Serious Explorations
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
I've busted 3 of the crappy cast metal companion flanges on my rear driveshaft in the last 2 years. Mark Williams makes a super heavy duty yoke and cap set which uses big 1350 U-Joints. I'm ordering one in the morning!
www.markwilliams.com/pdfcat/pg32.pdf
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Crankcase
Moderator Emeritus
Moderator Emeritus
Vancouver B.C, Canada
1992 XL Ex-Police
Nice....But then we won't get to see any more OH SH1T!!!! videos:D
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Cool! on to the next weakest link, eh Rick? :)
Ever thought about doing a full floater on your 8.8???
CoryL
Louisville, KY
94 Eddie Bauer
Doesn't exist anymore. Warn stopped making the kits at least 1-2 years ago. Wasn't enough market for them.
RFR2212
Typing Police
In the mug by Chitown
95 JEEP Wrangler
That's what Dana 60's are for :p
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
Cory, I asked Mark Williams about their C-clip eliminator kit for the 8.8" as with other manufacturers they don't reccomend it for off-road use.
They did mention that ne ends could be welded on the housing for a Ford big bearing which would also serve t oeliminate the C-clip. Not sure exactly what type of setup that is. Could you explain....
tiessen
Vancouver, BC
'92 XLT
Cut off the Ford 8.8" ends and weld on flanges for a big bearing 9" end. Instant C-clip eliminator.
BTW, I have a friend who makes full floater kits. Cut your ends, weld on his CNC'd ends, bolt on Dana 44 spindles, brakes, etc and have some custom shafts made. He's done 2 9" axles, but the 8.8" would be the same.
Cheers
Dale
soupbone
Hayward,CA
'00 Sport 4WD
eliminator
Dead Link Removed
Seems like alot of work. But work looks good.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
Good find, somehow I missed that article. Looks like an excellent way to make an 8.8" even beefier.
tiessen
Vancouver, BC
'92 XLT
Maybe your axle wrap is busting the flanges? Pinion dives under hard throttle or hopping and breaks the Ujoint and flange?
Just a thought, and I'm kinda cross posting from you rear spring post on Pirate.
Cheers
Dale
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
Yep, that has been part of it, but the cast flange is still a REAL weak point which is easily replaced. The difference between 1350 and 1310 joints is quite significant and using steel yokes on both ends will make for a strong setup. The last busted flange was the last straw.
RFR2212
Typing Police
95 JEEP Wrangler
Bah get a ProRock60... or a custom trimmed 60 :cool:
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
Can I use your CC# to order that $5000 axle you want me to have?:D
Dana 60 would be a great upgrade, but I would need new gears and a new ARB. Might as well just beef up what I have.
RFR2212
Typing Police
95 JEEP Wrangler
Sure.. After I get done with all my wheelin rig issues... So that'll be a long time! :p
Randall
Demon4x4 Member
Mo. City, TX
1991 Demon Edition
Callsign
KF5ZXT
Any more info? Contact info? site? price?
Thanks,
offroader_69_me
Trinidad, Crawlorado
'91 XLT
so the you would still have 1310 ujoints but with 1350 caps at the axle I dont understand?
soupbone
Hayward,CA
'00 Sport 4WD
Kinna off topic but couldnt you use big bearing 9" ends on the 8.8. $90
Then use warn FF kit for the 9" with solid drive flanges and custom FF 8.8 axle shafts? Need to figure out how to adapt the disk brakes..... no?
The 1350 yoke and MW bearing caps would finish it off.
or just get a 60 and get the tone ring and disc brakes on it :D
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
I just like my disc brake floaters... if the axle breaks the disc brake setup will keep the wheel on the truck :D
Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
I can understand the use of the yoke to replace the driveshaft flange, but why the main bearing caps. I haven't heard anyone having problems with those and with the support diff covers is it really needed?
soupbone
Hayward,CA
'00 Sport 4WD
I understand its just for high HP or V8 guys. Not needed at all. It was just in the same pdf as the yoke. ;)
