IronCamel
- December 26, 2005
- LV, NV
- 94 XLT (Manual)
I was out test driving my '94 after finishing replacing the water pump and a few other bits when I found a semi-new problem. I have been getting really random times where I suddenly get a huge amount of engine hesitation. It feels similar to what you would get from running with a couple of blown spark plugs (or something like popping the clutch while it's running). It has happened maybe twice before and started doing it right before the water pump blew so I figured it was something caused by the overheating.
The cooling system now works fine, but the hesitation is still there and I can reproduce it by simply driving uphill (about a 30 degree incline or more). If I shift out of 2nd gear and into 3rd it's fine. I don't know if it is the RPMs causing the issue, or if my second gear is starting to go.
What are some things that can cause this sort of thing that I should check before I start stepping into something really expensive like dropping the transmission?
