zekew64
- November 19, 2013
- Carbondale, IL
- 1992 Ford Ranger XLT
Hey e'erybody! My name is Isaiah; I've owned a '92 Ford Ranger for about 2 years now; been thinking lately about the custom engine I want to build...going to take many papers with dead presidents to make that happen, lol!
Hope all goes well here...I'm also on therangerstation.com, and fordrangerforum.com as well.
By the way, got a question for y'all out there.
When I replaced my 2.3L I4, and put everything back together, I hooked up my cruise control. The issue is that when I started my truck, it would act like it was at WOT; needless to say, it would rev higher and higher, without settling on a level RPM. I've disconnected it because of it, but I would like to be able to drive long distance and not have to have my foot on the gas constantly.
I do know that the vacuum hoses are good, along with the servo. I confirm this by disconnecting the actuator cable (connects to the TB), and when I started my truck, the servo had pulled the actuator cable tight, like it would have kept the throttle at wide-open.
Now, having said that, what would cause the system to act like this? The brake lights work, so I know it's not the brake switch. The only things I can think of that would be bad are:
1) Cruise Control Transducer
2) Cruise Control Amplifier
3) Bad Cruise Control ground? Where is it located? Motorcraft.com says that there is a ground wire.
4) Bad Cruise Control Inhibitor Solenoid, if it has one?
How do I track down the cause? I know that the rest of the vacuum lines are good, that the EGR and TPS works. I've also got mechanical skills, and fairly decent electrical skills; I know how to use a multimeter. I just don't know where to start, testing what components. Also, I don't know if it is relevant, but I had to take out my RABS fuse, as I think I've got a bad sensor in the differential (I only have rear ABS); I don't know if the cruise control would be tied to that system or not.
Thanks for all your guys' help in advance!
