I learned from experience that YOU DO NEED hub sizing adjustment.
I bought these from Bloxsports (seller on ebay) for $325 for a set of 4;
The wheel hub spec of Ford Explorer 2007 is bolt pattern 5x114.3 hub bore 70.5mm studs 1/2"-20;
The wheel spec of Ford Explorer 2013 is bolt pattern 5x114.3 center bore 63.4mm.
Need to customize made the Wheel adapters for bolt pattern 5x114.3 center bore 70.5 to 63.4.
A set of 4 pcs 1.5" inch: 295USD free shipping to the US
The price based on the following points:
1.Material: Aluminum Alloy 6061-T6
2.Manufacturing method: Forged
3.Studs:12.9 Grade, SGS Certificate for Limited Life Range Tested(1 Million Times).
4.Machining Precision: Circularity: 0.02mm, Perpendicularity:0.03mm, etc.
I can send you SGS detail reports if needed.
