Hi! I sure could use some Explorer advice | Ford Explorer Forums - Serious Explorations
Frehleychik75
1999 Eddie Bauer Explorer
I have a 6cyl 1999 basic Eddie Bauer.....recently I've replaced the battery, starter & fuel pump.....cranks beautifully but won't start....I've checked fuses, reset inertia switch, anti theft seems ok....fuel sensor...what am I overlooking? Crankshaft sensor? Relay?.....Thanks
Welcome to the forum. When you turn on the key without cranking the engine do you hear the fuel pump run for a couple seconds?. Check to see if you have fuel pressure at the Schrader valve on the fuel rail, check to make sure you have spark, Has the fuel filter been changed lately?.
@Frehleychik75
Hello & Welcome to the Forum!
Help us help you - In your Member Description (in blue background to the left of your post), please list what specific model V-6 you have:
* 4.0 OHV or 4.0 SOHC.
With that said, what stood out to @Mike65 stands out to me = when you replaced the fuel pump, did you replace the fuel filter?
If not, that's where I'd start.
$10 - $12 for the filter, $14 in ALUMINUM fuel filter tools from Harbor Freight pictured BELOW (don't buy plastic removal tools), and probably 1 hour labor for your first time at bat removing the filter. I also hope your fuel tank is 1/2 full or below or be prepared to get some gas on you ;)
shopping
For your engine to run you need a few things...
1. Fuel
2. Spark
3. Oxygen
4. Valve timing
As you have a 4.0L engine in an Eddie Bauer I assume it's the SOHC V6 rather than the base 4.0L OHV engine. Is this correct?
I hope you figure out your issue is something simple but... If you have fuel, spark and oxygen getting to the engine it should run unless your timing is off. This is a real possibility with the SOHC 4.0L V6, because that engine is infamous for developing timing chain problems. The timing chain components are housed within two cassettes, which have plastic parts. What usually happens is that the plastic breaks, leading to slack in the metal timing chains, which can then lead to the engine "jumping time". If the valves are not opening/closing at the right time they can slam into the pistons and bend, even if you valves and pistons don't collide your engine may not run when your timing is off by even one tooth and probably is not worth repairing. If the passenger side cassette breaks it requires engine to be removed from the vehicle to replace it. The driver's side cassette can be replaced with the engine in the vehicle, but is still a lot of work. Full set of good quality parts and special tools can run you over $2,000. even if you do the labor. Is a 1999 4-door Explorer (with weaker V6 transmission) worth investing $2,000 into? No, not in my opinion. Re-manufactured engines are available, but they will still cost you $2,000+ plus labor.
So, figure out if the engine is getting fuel, spark and oxygen. If these 3 parts of the puzzle are present, the next thing to do is a compression test to see if you've bent valves. Typically a compression test will show that one side of the engine has no/low compression if valves are bent.
Some simple tests:
Fuel test - Spray starting fluid directly into the throttle body for 2-3 seconds and crank the engine. If it tries to start on the starting fluid you're not getting fuel.
Spark test - Pull a convenient spark plug wire, take an old spark plug, attach it to the plug wire and using battery jumper cable ground the plug to the negative terminal of the battery. Watch the plug while the engine is cranked. You should see a very good spark. (Note: Don't try holding the spark plug by hand as 50,000+ volts will knock you on your ass).
Oxygen is kind of a given, especially if you've removed the intake tube to spray starting fluid into the throttle body.
Bent valves test - Do a compression or leak-down test on both banks..
Is the theft light blinking or does it go out when cranking?
Nobody asked about the pats key?? its a 99 with pats
crank crank crank and no start can likely be a bad PATS key
Good catch, never thought of that. :dunno:
Hay I love my rust free 99 4 door:)
Timing chains suck tho we need old school gears
@Frehleychik75
shopping
I bought the same tool kit and you arent kidding about it taking awhile, they seemed to slip in easily enough but pushing in on the line and pulling out wasn't seeming to work but then finally did. PS I used the pull up harbor freight lantern to light my way on this job.
