Tools Needed:
Drill, 5/16 drill bit, 17/64 drill bit, File, & Pliers.
Parts needed:
1/4" x 1-3/4" Safety Snap Pin
5/16 x 1-1/2" Cotterless clevis pin with a ring.
Both parts were found at Home Depot, with a total cost of about $5.
Step 1, Remove cotter pin holing handle in.
Step 2, Drill a hole using the 17/64 drill bit all the way thru the handle, using the cotter pin hole.
Step 3, File any burrs off.
Step 4, Test fit Handle, Running gear and 1/4" x 1-3/4" Safety Snap Pin.
Step 5, Remove cotter pin holing base on to steel bar.
Step 6, Drill out cotter pin hole in base with 5/16 drill bit.
Step 7, File any burrs off.
Step 8, Test Fit Steel bar, Base, & Cotterless clevis pin with a ring.
Optional Method
Purchase 2, 1/4" x 1-3/4" Safety Snap Pin.
Step 1, Remove cotter pin holding handle in.
Step 4, Test fit Handle, Running gear & 1/4" x 1-3/4" Safety Snap Pin.
Step 5, Remove cotter pin holding base on to steel bar.
Step 6, Test Fit Steel bar, Base, & 1/4" x 1-3/4" Safety Snap Pin.
Parts needed:
Optional Method
