HID Install +Pics - Step by Step
corpflyboy
Melbourne, Florida
2014 Ford Explorer Sport
Just an update on my headlight HID install...I had to replace the coolbulbs-square 3m double sided pad after only a couple weeks. Both sides fell off. I replaced it with RED 3m tape which required three strips per transformer. The original smaller transformer is still holding strong with the RED 3m tape that I HAD to use-coolbulbs does not supply double sided tape for that piece. Hope this helps for future DIYers.
adamantium
Orlando, FL
2013 Ford Explorer Sport
For you guys running hids in the fog lights, how did you disable the relay that cuts them off when you use high beams?
mabupa
florida
2013 explorer limited
In my case, I left that untouched. I never run high beams anyways.
corpflyboy
Melbourne, Florida
Nothing!
Simple install...Work just like normal...High beams turn on...Fogs turn off. Order them up! Buy 3m Red Tape!!!
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Nothing!
I think the question was how do you disable the relay that turns the fogs off when you use the high beams. In other words I believe the posted wants both fogs and high beams on, although I don't know why. Not sure if that is even legal in most places.
adamantium
Orlando, FL
I ask because if you need to flash the brights and have hids on the fogs they will get quick power interruptions which I don't think the ballast like too much maybe causing premature failure.
corpflyboy
Melbourne, Florida
Good point...forget being courteous and save your bulbs! :smokinfro
JScoot
Orlando, Florida
2013 Explorer Sport
Maybe I missed it, but has there been any update to Wibb's posts above (e.g., # 40 and 38) regarding the conversion to HID headlights and projectors using OEM HID components and the anticipated costs to do so? Wibb (or anyone else with knowledge), please let us know if you have obtained any additional information on this, as it appears several members are interested.
Also, am I correct in assuming that any such conversion would require the headlight assemblies to be opened up by heating/baking them?
deadmanx
370z sold Now 2014 Xsport
any updates on how kits are doing? are there differences between canadian and US explorer sports regarding DRLs? i dont think i have DRL's on my Xsport? I really am interested in this kid just not sure on how things are going! Thanks guys
also noticed the Limited comes with HIDs so i wonder if FORD would do a swap?! :)
How is this setup (coolbulbs) compared to how the HIDs are setup on the Limited? ie how they are controlled etc... ?
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
No difference between US and Canuckastan as far as hardware just federal law.
In Canada federal law says any vehicle sold must have DRL's, but not in the US.
If your vehicle has HID projectors then the park/turn/warn amber lights are your DRL's.
If your vehicle has halogen projectors then they are the DRL's
deadmanx
well i have a 2014 explorer sport so i dont have HID projectors. My question is since i live in the united states and dont have DRL's to my knowledge, will me installing these HIDS give me any issues?
corpflyboy
Melbourne, Florida
The only issue you will have is that you will be able to see at night. Good Luck with that.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
No issues, but as several have mentioned on here do not use cheap Ebay kits.
Coolbulbs.com seems to be a good kit, just a recent rash of issues with their supplier from China. Hopefully its all resolved now.
I like the CANBUS connected kits.
Im only waiting to see what happens with the guys who were looking into the Ford OEM HID parts and making their own kits to install on the Halogen Sport headlights.
deadmanx
This is what id really like.. who is doing this? Any progress??
Someone with a limited (with hids) needs to check and see if the ballasts are on the bulb themself or how that works... the headlight housings have to.be the same I would think from.limited to.sport (Aside.from blacked out)
peterk9
Staff member
Moderator
Callsign
VE3
No they are not the same according to a few articles I have read. They are designed for the OEM bulb that is used.
Halogen headlamps and HID headlamps require very different optics to produce a safe and effective—not to mention legal—beam pattern. How come? Because of the very different characteristics of the two kinds of light source.
A halogen bulb has a cylindrical light source: the glowing filament. The space immediately surrounding the cylinder of light is completely dark, and so the sharpest contrast between bright and dark is along the edges of the cylinder of light. The ends of the filament cylinder fade from bright to dark. An HID bulb, on the other hand, has a crescent-shaped light source -- the arc. It's crescent-shaped because as it passes through the space between the two electrodes, its heat causes it to try to rise. The space immediately surrounding the crescent of light glows in layers...the closer to the crescent of light, the brighter the glow. The ends of the arc crescent are the brightest points, and immediately beyond these points is completely dark, so the sharpest contrast between bright and dark is at the ends of the crescent of light.
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
breshi
2013 Ex Limited FWD V6
the factory hid on the limited has a separate ballast that sits on the bottom underside of the headlight housing. the bulb is a d3s which has a square box like back part with the glass bulb sticking out of it. there is a cable that runs from the ballast to the bulb. the HID housing is different than the halogen version.
deadmanx
Ah. Thanks for the info, I figured they would be similiar but I guess not.. sucks lol.
peterk9
Staff member
Moderator
Callsign
VE3
It hasn't prevented members from doing a conversion as you can tell by the various threads on the topic. It just means that they won't be as good as the OEM installation for the reasons provided above.
deadmanx
well I think I will wait to see if anyone converts the limited HID's to the Sport in some fashion. I think that would be ideal
deadmanx
Talking to salesman that I dealt with , he is going to speak with service manager to see if sport housing can have hids from limited wired up and used in that housing. Keep ya posted even though I dont have good feeling or that anything will come.of this, but we will see.
M HID Install - Fogs +Pics Modified 2011- 2019 Explorers - Tuning & Mods 13
N HID Conversion Kit... eh, rethinking the install Modified 2011- 2019 Explorers - Tuning & Mods 31
S Battery saver mode after HID install Modified 2011- 2019 Explorers - Tuning & Mods 8
A HID Fog Install Questions Modified 2011- 2019 Explorers - Tuning & Mods 20
M Any Canadian's install HID's? Modified 2011- 2019 Explorers - Tuning & Mods 2
C HID's or LED's - these halogens have to go Modified 2011- 2019 Explorers - Tuning & Mods 3
C User reviews on HID kits (consolidated) Modified 2011- 2019 Explorers - Tuning & Mods 20
N Diode Dynamics HID Users... come on in! Modified 2011- 2019 Explorers - Tuning & Mods 22
T Removing OEM Hid Headlight Bulbs Modified 2011- 2019 Explorers - Tuning & Mods 7
T HID Beam Pattern Thread Modified 2011- 2019 Explorers - Tuning & Mods 1
N 2015/2016 Ford HID/LED vs Aftermarket... which is better? Modified 2011- 2019 Explorers - Tuning & Mods 15
R 35W or 55W HID bulb Modified 2011- 2019 Explorers - Tuning & Mods 34
R 2012 headlights hid to halogen Modified 2011- 2019 Explorers - Tuning & Mods 5
S DDM HID Slim Kit Issues Modified 2011- 2019 Explorers - Tuning & Mods 10
J HID/LED Headlamps and/or Fog Lamps - GO LIONS!! Modified 2011- 2019 Explorers - Tuning & Mods 3
D Informative Pros/Cons Halogen, HID, Retrofit lighting setups Modified 2011- 2019 Explorers - Tuning & Mods 0
C My Drivebright.com experience (HID and LED Swap) Modified 2011- 2019 Explorers - Tuning & Mods 22
2 One Side HID Not Working Modified 2011- 2019 Explorers - Tuning & Mods 17
C Having an issue with HID's Modified 2011- 2019 Explorers - Tuning & Mods 18
P Which Headlight HID Kit??? Modified 2011- 2019 Explorers - Tuning & Mods 34
S Ford explorer HID get exchanged to Halogen by dealer Modified 2011- 2019 Explorers - Tuning & Mods 9
1 35W vs 55W HID? Modified 2011- 2019 Explorers - Tuning & Mods 16
C Correct positive connection for HID relay Modified 2011- 2019 Explorers - Tuning & Mods 1
K 2014 Ford Exploer Limited HID from Diode Dynamics Modified 2011- 2019 Explorers - Tuning & Mods 26
J HID Conversion Problems-2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 99
C Canbus or regular harness for HID? Modified 2011- 2019 Explorers - Tuning & Mods 21
O HID's and Shark Fin on Leased Sport, input requested. Modified 2011- 2019 Explorers - Tuning & Mods 5
Sgt1411 Installing HID? Read this first. Modified 2011- 2019 Explorers - Tuning & Mods 168
J My experience w/ House of HID Modified 2011- 2019 Explorers - Tuning & Mods 25
X TRS HID or Cool Bulbs Modified 2011- 2019 Explorers - Tuning & Mods 12
R Question for the Folks that installed HID on the FOGS Modified 2011- 2019 Explorers - Tuning & Mods 6
M HID Upgrade in Canada Modified 2011- 2019 Explorers - Tuning & Mods 7
F Coolbulbs.com HID Kit Review - Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
I Coolbulbs All-In-One 6kk HID's (heads and fogs) in my 2013 Explorer Sport Review Modified 2011- 2019 Explorers - Tuning & Mods 8
J 2013 Ford Explorer Sport Tint and HID Mod Modified 2011- 2019 Explorers - Tuning & Mods 6
K Help with HID ballast mounting Modified 2011- 2019 Explorers - Tuning & Mods 15
R My last post ------- about HID! Modified 2011- 2019 Explorers - Tuning & Mods 3
G HID low beams/HID Fogs Modified 2011- 2019 Explorers - Tuning & Mods 22
M HID Light Installation - HELP!!!! Modified 2011- 2019 Explorers - Tuning & Mods 14
E Morimoto Elite HID Kit Installed Modified 2011- 2019 Explorers - Tuning & Mods 14
J Replacing OEM headlights with HID lights? Modified 2011- 2019 Explorers - Tuning & Mods 52
R 2013 LTD with HID Modified 2011- 2019 Explorers - Tuning & Mods 15
M Ford Explorer HID Conversion Kits - Installation Guide Modified 2011- 2019 Explorers - Tuning & Mods 15
J DDM Tuning HID Kits - Don't waste your time or money Modified 2011- 2019 Explorers - Tuning & Mods 6
S Ford HID bulb upgrade Modified 2011- 2019 Explorers - Tuning & Mods 9
R HID bulb problems Modified 2011- 2019 Explorers - Tuning & Mods 13
N My Sport with HID 8000K's Modified 2011- 2019 Explorers - Tuning & Mods 97
F New Guy with ?? on HID kits Modified 2011- 2019 Explorers - Tuning & Mods 17
N Ford Explorer HID Conversion Kits (problem?) Modified 2011- 2019 Explorers - Tuning & Mods 72
C Explorer 2011 - HID Headlight Issues Modified 2011- 2019 Explorers - Tuning & Mods 5
Similar threads
