3xplor3r
- December 20, 2006
- jersey
- '96 Eddie Bauer
Hey, alright so im putting 2x of 12" Rockford P2 Subs(stats below) on there, each with a 200watt RMS and a 400watt Peak. I'm going to wire them like this so the amp onl needs to put out a 2ohm output:
My question is what hifonics amp should I look for, I'm new at this and i'm still learning the ropes. Any likes to ebay, a store, etc. would be great, as well as any other suggestions. Thanks!
Sub Stats:
Subwoofer Size: 12"
Impedance: 4 ohms
Dual Voice Coil: No
Peak Power Handling: 400 watts
RMS Power Handling: 200 watts
Woofer Surround: Foam
Woofer Composition: N/A
Sealed Box Volume: 0.75 - 1.25 cu. ft.
Ported Box Volume: 1.25 - 2 cu. ft.
Sensitivity: 86dB
Frequency Response: 20 - 200Hz
Xmax (millimeters): N/A
Top Mount Depth: 6.125"
Cutout Diameter: 11-1/8"
Sub Stats:
Subwoofer Size: 12"
Impedance: 4 ohms
Dual Voice Coil: No
Sensitivity: 86dB
