high altitude | Ford Explorer - Ford Ranger Forums - Serious Explorations
high altitude
Estes
Lower Brule SD
1994 Eddie Bauer
I have a 1994 eddie baurer explorer. it was originally a rental unit in Denver, on the window sticker, it has the high altitude package. Anyone know what this is. thanks
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
on a 94 Explorer high altitude = maybe a different computer tune, that should be it.
Possibly full undercoating, but with todays trucks (yes even 94) the computer can make enough adjustments to get you through the rockies without needing a special timing/air/fuel ratio.
If anything you should have more power at sea level then maybe a non high alt computer would be tuned for (more timing) make sure you run 91 octane in it if it starts to ping at sea level.
