Solved - High Idle - 91 Explorer Eddie Bauer | Ford Explorer - Ford Ranger Forums - Serious Explorations
Solved High Idle - 91 Explorer Eddie Bauer
azrael_ak
Wasilla, Alaska
1991 Explorer Eddie Bauer
Is there anyone out there that can help me with a high idle problem?
The issue i am having is the engine kicks from normal idle (800ish rpms) to a very high idle (1800 rpms) for no reason. I know on some cars you can hear it click and it idles up a little bit but nowhere near like this problem.
I have replaced the Idle Air Control Module (went thru three of those to rule it out, also tested the jack with a multimeter), the Mass Airflow Sensor, the TPS, the PCV valve. I'm running out of ideas on what it could be.
Any help would be greatly appreciated.
A clerk at napa said something about a MAP control unit? But i don't know enough about it to say.
This problem is killing my gas consumption rate as well. My trip meter says 55 miles and i am a little over a half a tank. With winter coming and having to warm it up every morning, i would like to get this fixed asap
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
I think I'd try some easier cheaper things before I replaced the MAF sensor.
Are you sure you don't have any vacuum leaks? That can cause irregular idle, and if the FPR vac line is broken, I can see that causing low mpg.
How about the throttle cable -- is it binding? Check near the gas pedal, and near the throttle body. Also make sure the throttle plate (in the throttle body) is not gummed up with carbon. It should move easily with no obstructions.
Sometimes the a/c compressor will get stuck on, and the extra load will idle it up, too. Usually you can hear the compressor clutch popping off and on in that case.
azrael_ak
Wasilla, Alaska
Don't hear anything out of the ordinary. Did a vacuum test and its normal. The only thing that you posted that sounds familiar is sometimes i go to leave and push the gas pedal and it seems to be hanging up. But i don't think its related. The idle thing happens by itself for no reason. Yesterday i was watching it and it was sitting at 850rpms and it just clicked and jumped up to 1800. then i noticed it would sometimes click and go back to normal for about 3 seconds...then jump back up.
So something is telling it to jump up. It usually happens after it warms up a little. Never does it while its cold.
Currently my air conditioner isn't charged. Think that would cause something like that? I had a leaky adapter on the A/C dryer cannister and had to find a replacement. I think tomorrow i will put on the new adapter and recharge the system. I don't think its related. I've watched it with the hood open and the clutch on the A/C pump doesn't engage when it happens.
Been beating my head against the wall for almost a year on this problem.
Centaurious
Pensacola FL
1994 Explorer Sport
I would clean the throttle body/butterfly, test the Throttle Position Sensor for smooth readings when operated, remove the EGR Valve from the intake and ream out the carbon in the passage behind it and I would check the codes for any clues
azrael_ak
Wasilla, Alaska
Will try that. No codes. Checked for those first. I replaced the throttle position sensor earlier this year. It had smooth movement. But i will check it again. Tested everything with a multimeter and everything checks out. I will clean the EGR tho, I didn't think of that one.
Centaurious
Pensacola FL
1994 Explorer Sport
That passage behind the EGR stumped me for a couple of days when I got my 94. It's about 1/2" or 13mm and mine was completely solid with carbon. In my experience these sudden changes that revert themselves are almost always electrical or electrical related. In order to affect the idle it must either relate to Fuel, to Air, or to Timing. Something as simple as the Charcoal Canister Purge Valve can affect the engine running if say the Charcoal Canister was damaged, thus allowing extra un-metered air into the engine at highway speeds.
Best of Luck
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
For sure, yes. The clicking you hear is the a/c compressor clutch cycling, trying to maintain pressure with what little refrigerant is in there. You should not be seeing a jump to 1800 rpm, that means the compressor clutch is putting a bigger load than normal on the system. It may be wearing out. Try charging it (relatively cheap to do) and see if it improves.
azrael_ak
Wasilla, Alaska
I tried charging it but i found that the high pressure A/C line is damaged and i will have to save up to replace it. Had to use a leak detector kit to find out where it was leaking but i did. I never did see the pump kick on.
Dora 1993
Fargo, ND
1993 Explorer XLT
If the AC is related but you don't want to fix it right now you can just unplug the compressor for now until spring. Then your idle won't go nuts when its warming up.
azrael_ak
Wasilla, Alaska
My brother figured out the problem. The mass airflow sensor that i purchased new from Napa died after being in the car maybe two weeks tops. Thank you for all of your suggestions.
Centaurious
Pensacola FL
1994 Explorer Sport
I would wonder why it died. Are you running a K&N oiled type air filter that might have contaminated it?
azrael_ak
Wasilla, Alaska
Yes I am running a K & N air filter but its been in the car for about 3 years with no issues. I don't think that would be the cause. The more likely cause is someone bought it....then returned their broken one. It's the oldest scam in the book. I was in a AutoZone recently and was getting an air filter. Someone had purchased a K & N filter for their vehicle. Then returned the K & N box with their crappy used paper filter which looked like it was at least 5 years old, in the K & N box. Was about 100$ that they had to eat because they didn't check the box when it was returned. I suppose they have no way in testing mass airflow sensors.
