jwarwick
- August 7, 2014
- The Thumb, Michigan
- 2003 Explorer XLT 4.6
2003 Ex with the 4.6L and 143k miles.
At a warm or cold start up, the RPMs jump to 2k then very slowly drop to around 900-1k.
While driving, the RPMs stay higher than normal when the trans is shifting. It seems like the RPMs are 300-500 RPMs higher than normal. There have been times where I've been driving 65+ mph and the trans will finally shift into 5th.
My gas mileage has been abysmal as well.
I have replaced the IAC with a Motorcraft one and this fixed an idle surging issue from a previous post: http://www.explorerforum.com/forums/showthread.php?t=412653
I recently tired a replacement TPS and the high idle at start up and shifting still continued.
I have cleaned the throttle body, MAF and EGR valve. There are no vacuum leaks and the rubber hoses are all good.
I have reset the PCM (no luck) numerous times via the video in this link: http://www.explorerforum.com/forums/...d.php?t=396533
Any thoughts??
thanks in advanced
Any thoughts??
thanks in advanced
