mailboxman
- December 8, 2009
- Latrobe PA
- 1994 Splash 4.0
need some help guys--i have exhausted the rangerstation forum for responses and was not able to fix my idle--
Replaced:
MAF
IAC
TPS
ECT
Spark Plugs
Wires
PCV
Have reset computer multiple times--bought a new thermostat that I will be installing tonight-and also bought another can of carb cleaner (this is the third can) that I will search again for vacuum leaks.
My cold idle is 1500+ and after warmup goes to 1200rpm
Cant find a vacuum leak and vacuum always pulls 20 on the gauge.
If I unplug the IAC my idle goes down to about 600 rpm but presents other drivability issues such as wont idle when cold.
If I unplug and block the pcv valve it idles perfectly-but i am worried about sludge in the engine.
If it were a vacuum leak, would idle go down so low when I unplug IAC???
And why does it idle so good when I block the pcv hose???
If anyone can help it sure would be appreciated
thanks
Replaced:
MAF
IAC
TPS
ECT
Spark Plugs
Wires
PCV
thanks
