Bones192
- July 10, 2003
- Salt Lake City, UT
- '92 XLT
I have a 92 X that has an idle problem and it seems to occur after warmed up and possibly after a heavly load at low RPM. But it is erradic, so I have read the many threads on the topic and tried many of the suggestions. I have replaced the following: TPS, IAC, and the MAF. The RPM at first were hanging at about 1500-1800 RPM when I can to a stop after a few mile run. Now the RPMS are closer to 2200. If I turn the enigne off for a few seconds ,after the failure, and when restarted it returns to a normal idle. I think this would elminate any mechanical failure (vacuum leak, bad connection etc.) What should I consider before I send this thing to the dredded service shop? Any insight is greatly appreciated.
