High idle upon start-up regardless of cold or hot starts | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
///Manuel
Denver, CO
92 XLT
When I start the car, the idle raises up to 2k then slowly decreases to 750 rpm's after a minute or so.
I swear that it wasn't revving so high in the past. When warm it goes to about 1.8k maybe a touch lower.
When I disconnect the idle actuator, there's no such surging anymore.
I checked the pcm engine coolant temp sensor resistance but I'm not sure about its specs.
It seems to be working (increasing resistance with the decreasing of the temperature).
Everything else seems to be functioning properly (IAC, MAF, air filter, no vacuum leaks, TPS, CPS, O2, no codes).
Manuel
Jason94sport
FL
02 Sport 2WD 5 speed
Likely a bad TPS on the throttle body. Replace it. It will not show any code if it has an issue.
Take the IAC off & clean it as well.
///Manuel
Denver, CO
92 XLT
But the TPS checks out ok, voltage-wise, I get 4.61V full throttle and .8 to 1.1V depending on my adjustment at idle (neither seemed to make a difference).
I swapped the IAC with my old one, same exact behavior.
///Manuel
Denver, CO
92 XLT
Also, I started the car with the tps disconnected and got the same behavior as well as a check engine light.
I need to find out the specs for the coolant sensor. It's the most likely culprit I believe, or maybe I could just swap it anyway.
