VTExplorer
- January 2, 2004
- Vermont
- '96 XLT 5-speed
You gotta help me guys. I'm going crazy here....I've read a ton of idle-related threads but I can seem to pinpoint what my problem is.
Once my '96 is warmed up, it'll idle pretty good in the driveway, around 1000 rpm (a little high). Once you start driving its a different story. If I shift into neutral, or just push in the clutch at say 30 mph, the engine speed will rise to between 1500 and 2000.
If I coast down a hill in neutral with it idling high, once I reach the bottom of the hill and stop for a few seconds, the idle will drop to around 1000. Does this mean a brake booster-related vacuum issue?
I checked for vacuum leaks, both visually and with a propane torch. No luck. I cleaned the IAC. When the IAC is unplugged it idles at between 500 and 750. The TPS is reading properly (0.97 volts). Is there anything else I can do besides take it to the shop?
Al
Al
