Byrd91
- December 3, 1999
- Penobscot, Maine
- '92 XLT
I just bought a 4 channel amp that has 2 separate sets of RCA level inputs and 2 sets of speaker level inputs. My headunit only has one set of RCA level outputs and I was wondering what will be the best way to connect the amp. I'm going to run the front door speakers with 2 channels of the amp and eventually run a sub with the other 2 bridged. I'm either thinking to run wires from where the speaker wires go in to the factory amp(from the head unit) into the high inputs of the amp and then run wires from the speaker outputs of the amp back to where the speaker wires leave the factory amp for the front speakers. I could than use the RCA outs of the headunit hooked to the rear channel of the amp for the sub. This option would allow me to keep the fade control. The next option would be to run the RCA cable from the headunit to one input in the amp and than run a short set of RCA cables from the preamp outputs of the amp to the other channel of RCA inputs in the amp. This would make cleaner connections and my actually allow better use of fade control since I still have the weak factory speakers in the back doors. Plus I can always turn the the bridged channel up higher than the front channel on the amp right. These are my thoughts, what do you guys think. Also, I'm thinking about mounting the amp under the rear seat, will I still be able physically to fold the seat down. I know I probably shouldn't run it hot with the seat down. Any help would be greatly appreciated.
