High milage explorers? | Ford Explorer Forums - Serious Explorations
01EB5.0
Allendale, MI
2001 Eddie Bauer V-8 AWD
i was just wondering if people could post the milage, year, and what major parts have had to be replaced just so others can see what to expect when our mileage gets up there. i have a 1995 XLT with 78,000. Thanks
(ALso tips on making the Explorer last longer would be helpful!)
*New info: Now I have a 2001 Eddie bauer 5.0 shown at the right. It now has 71,000 on it. The 95 lasted me till 122K when I crashed it offroad (oops).
Lets see if the 2001 can double that! :)
TravisN1@AOL.COM
1995 XLT 4x4
93' 4x4 4 door
69,948 miles
ball joints, thermostat, plugs, wires, and air filter
Nick
'93 XLT 4 Door 4x4
95 sport 4x4 4.0 OHC V6
64,000 miles
Here is a list of everything that has been replaced.
Radio,
Speedometer head,
Throttle cable (twice)
Seat belt
fog light assembly.
engine thermostat
Repaired
cleaned Mass air flow sensor
Now whats wrong. Speedometer head again
CD changer won't work. Need a new one. 4X4 Low keeps popin. Heard it was usual though for it to feel like the front axle is coming out form under the explorer. Radius arm bushing needs replaced.
It's been in to be fixed more than it's been drove as it seems. Any else have this problem.
I have a 91 4.0 w/150,000
I have had to replace the clutch, clutch slave cylinder, fuel pressure rgulator, o2 sensors, plugs and wires. I haven't really had too much trouble with the engine-except for the bad gas mileage which was for the most part cured from replacing the sensor and regulator- but most of my problems have been with the tranny. What a pain!! I am thinking about getting an auto put in and have a B&M automatic shifter put in to get rid of that stupid clutch which I have had most of my problems with. Well I guess some tips would be get all your tune-ups done on schedule and maybe even before schedule if you drive off road. And just take care of it by washing it and waxing it to keep the paint nice and shiny, and cleaning the inside to prevent damage to it. I have kept my interior nice and it practically looks brand new.
1991 XLT 4x4 4.0L AT
80k Miles and some change.
Overhauled Transmission, Replaced Wheel Bearings, Anti Rattle Clips installed, Two U-Joints, Thermostat, Main A/C Line, A/C Compressor will be replaced to eliminate noise at the beginning of summer, Rear-end will be overhauled soon, Replaced Cooling Fan.
'91 Explorer, 4-Door, XL, 5-spd Mazda trans, 4x4, 4.0L, A/C, Tow package, 250,000 miles
Comfortable
Plenty of room(Wife, 4 kids and I, plus accompanying travel gear)
Plenty of power(yes I have towed through the Rockies)
Extremely reliable, excepting trans
Dislikes:
Trans: geartooth broke at 150K had to replace all bearings, input shaft, and countershaft, and now 100K later it is acting up again(could just be clutch since it has never been replaced, though it feels worse than just the clutch)
Things it has needed:
Oil&filter change every 3K
Tune-up every 10K
Misc. fluid changes every 25K
Radius Arm bushings per TSB
Battery cable & box per TSB
Rear window replaced due to neighborhood vandals
4 door handle pulls(4 kids are rough on them)
Three sets of tires
Windshield wipers & lots of fluid(It's sure fun to get it in condition to need that much fluid)
1 speeding ticket(OOPS)
Engine still runs great but since I have to pull the trans I will freshen it while it is out.
No, I haven't done any mods yet(It's the family car until the '64 Fairlane is finished), BUT I am looking forward to what I get to do to it soon. I wouldn't trade it. Oh yeah, I would get another in a heartbeat(old body style, of course).
[This message has been edited by leftover (edited 01-30-2000).]
93' SPORT
94,000 MILES
MINE HAS BEEN VERY RELIABLE. HERE IS A LIST OF NEEDED REPAIRS:
--RADIUS ARM BUSHINGS
--DOOR AND GATE "LATCH" BUSHINGS
--STARTER (MY FAULT--SUBMERSED IN MUD)
--THREE SETS OF FRONT WHEEL BEARINGS
--NOT LISTING WEAR-ITEMS OR ROUTINE MAITENANCE
THE VEHICLE IS MODIFIED:
5.5" SPRLFT
4:56
EZ LOCKER FRONT
35" M/T MTX TIRES
ETC,ETC
I have a 91 with 287,000 miles
The only thing that I have replaced is the oil, plugs, wires, etc....Just the normall tune up stuff.
Scott Bauer
'91 Eddie Bauer
1992 Four Door. W/ 146,000 miles
Oil
Plugs
Wires
Fuel Pump
Radius Arm Bushings
Rebuild Trans (auto)
Brian Green
92 2wd Explorer w/
6 inch Suspension lift
92 2wd Ranger w/
5.5 inch suspension lift
Trckmagik@aol.com
I have a '91XLT bought August of '90. It has 145K on original 5spd trans, engine and paint.
Things that I've replaced:
Radius arm bushings (2x)
Shocks for Rancho RS5000
Tires (3x)
Radiator for custom three row all aluminum
Muffler for Dynomax Ultra-flo stainless
Cat for Dynomax Superconverter
New custom bent aluminized steel pipes
Waterpump
Power steering pump and hoses
Brake pads, pistons, cylinders
Master cylinder
Air conditioning condenser (2x) and hoses
Plug wires for Splitfire Twin-core
Plugs for Autolite Platinums (1) currently Bosch P+4
Altenator and regulator for remanufactured Bosch
Blower motor with after market motor
Fan and fan clutch
Air filter with K&N drop-in and modified airbox
Fuel pressure regulator
Fan belt with Goodyear Gatorbacks once every two years
Fuel filter once every year
Tensioner pulley and idler pulley
Rear gate strike pins
Oil and filter every 3months Castrol Syntec 5-50 or Mobil 1 15-50 AC Delco filter
Antifreeze once a year
I think I got everything. Currently my driver's side window seems to have lost a couple of gear teeth and needs replacing.
[This message has been edited by S.Matsushige (edited 01-30-2000).]
I just bought my 1992 Eddie Bauer Explorer about four months ago, it has 193,000 miles on it so far. I have been completely happy with it so far.
I have taken it in and had the following done,
-new front rotors
-new brake calipers
-new rear axle seals
-new starter
-new battery cables
-new shocks
-new tires
note: except for the starter and battery cables I bought the vehicle knowing that the other parts needed to be replaced.
1997 V6 XLT Controltract, SOH, 73,250 millage
- K&N Drop-in Air Filter
- Flowmaster muffler
New Brakes -(front and Rear)
New Tires - (Michellin M/S LTX)
New Plugs
Thats it! Everything works good.
No pinging! Dead Link Removed
NY State of Mind
91' xlt 4.dr
puchaced in 97'
[part's replaced]
rear steel brake line
R/A bushings
shocks
31x10.5 wide conquorer A/T
I will never sell my explorer
runner
1991 XLT 4 X 4 158,000 km
1) flex plate (flywheel) 2 times. Big bucks.
2) auto hubs 2 times (went to manual)
3) front rotors
4) radius arm bushings 2 times (went to polyurethane)
5) U-joint
6) voltage regulator
7) front/back brakes 2 times
8) lower ball joints
9) spark plug wire 2 times
10) starter motor
And what's next you ask.
1) replace leaky radiator and hoses
2) replace top drivers' door hinge
3) roof needs repainting/clearcoating
4) alternator
5) slight leak at power steering pump
6) u-joints might need to be replaced again
Would I buy another Explorer. I honestly don't know.
Syder-1
doo doo happens
Well, I have to list items that were not caused by my extreme off-roading, since that certainly is not the trucks fault.
93 Eddie Bauer 4-door (highly modified)
86,000 miles
transmission servo
thermostat
fan clutch (fried by frozen thermostat)
fan (partially melted by frozen thermostat)
radius arm bushings (no longer have them)
transmission mount
brakes
front wheel bearings
Thats about it.
Gloria
1992 XLT 4 wheel drive 185,000miles
What we replaced becuase we needed to (other than tune up stuff):
Tranny rebuild @ 165,000 miles
Radius Arm bushings
O2 sensor
Brake calipers and rotors (do the rotors every 2 times I change the pads)
replaced A/C lines (were leaking slightly)
What we replaced becuase we wanted to:
Added 2.5" lift
Added 8.5" shackles
Rs9000 shocks
Gears (3.27 to 4.10)
Detroit Locker in rear
Warn manual hubs
What we are about to change:
Alternator... its making noise when cold.
Other than radius arm bushing problem which were solved by the Lift (it moves the bushing away from the Cat) we have not had any chronic problems.
Mark
mark@legendz.com
http://mark.legendz.com
Off-Road and Motorcycle Information, Pictures and Movies
'93 XLT 105,00 mi
Replaced:
Radius Arm Bushings
Thermostat
Rear axle seals
Trans filter
Spark plugs
Brake pads & shoes
Shocks
Muffler
Belt
Fuel filter
Air filter (got K&N)
3000 mi oil and filter changes
I think that is everything.....
'92 EB auto 115k
non service items replaced:
AL4D @140k Dead Link Removed
P/S pump (leaking)
Fan (had cracks)
voltage regulator
Most gaskets (done under warranty)
auto hub (manual is next)
temp sender (after replacing two good thermostats)
I'd lke to replace the fake idiot oil temp gage (nope, they are not real gages! Ford engineer confirmed this on Truck Haven trip)
summation:
I love my truck, it has been really reliable. No vehicle runs forever w/o some tlc. Except for trans, I think everything has held up fine so far! I recommend them!
"Don't go where the road don't go." -Ringo Starr
Wil - '92 EB
i have a 91 w/ 173,000
the only problems i have had are the engine was replaced at 150,000, and the wheels at 165,000. the engine didn't need to be replaced, but it needed a little work and my dad found a better deal on replacing the whole engine. i wish it would have been mine back then, i would have put in a v8. the wheels had to be replaced after an off-road incident.
