firefly1246
- November 23, 2010
- Greenville, SC
- '04 EB
Hey all,
Thought I would start a thread to show what maintenance has been needed on my 2003 Explorer Sport Trac XLT 2WD, now that i have owned it over 3 years. This truck is now my primary daily driver now that my 2004 Explorer EB has been totaled by someone pulling out in front of me and my Corvette has been sold to make way for a minivan for the wife and our newborn twin boys.
Truck is a 2003 Red XLT 2WD, 4.10 limited slip, center console, overhead console, factory hard bed cover
The truck was purchased brand new by my Father in Law in 2003. Garage kept its entire life, oil religiously changed every 5K, and typically maintained at the Ford Dealership. Zero rust as it never left the state of NC. To make keeping up with oil changes easy to remember he would change it whenever the odometer hit 5K. So even if it was a hair early or a hair late it would get changed when the odometer rolled.
I purchased it from him Nov 2015 after the transmission wore out at 227,064 miles. So initialing i was going to just fix it up to flip it, but ended up really liking it. The body and paint was in really good shape, just a couple rock chips, the front seat was worn out, the steering wheel worn out, and the body mounts were worn out. He had just put a bunch of money into replacing the brake pads, and the front upper and lower A arms and balljoints. Note the tranny fluid had never been changed, failure was the bands were finally worn out.
227,064 - Nov 2015
-Replaced transmission with a used 176K tranny from a wrecked 03 Explorer Sport, replaced front and rear gaskets and seals. It was the lowest mileage one I could find locally that was already pulled. Flushed a bunch of Mercon V through the torque converter and transmission. Put a new Motorcraft Filter, have 2 magnetic strips (took the one from the old tranny), and had a drain plug welded into the pan. Adjusted the bands
-Cleaned up engine bay, 12 years of gunk
-Replaced Anti-roll bar bushings - Prothane
-Replaced Shocks - Rancho
-Replaced diff lube oil, friction modifier, and painted diff cover
-Replaced Front Driver Seat, found a used one out of a wrecked 45K Sport Trac
-Installed Aftermarket Seat Heaters, wired with a relay to the OEM seat heater fuse box.
-Replaced Steering Wheel with used one from a wrecked Sport Trac
229,811 - Dec 2015
Drove it around town and up to Richmond, VA and back ran great
-Dropped Tranny pan and replaced Mercon V and cleaned up magnetic strips
-Changed Oil Castrol High Mileage 5W-30, Motorcraft Filter
-Swapped out the transmission output housing seal with a Motorcraft one, the first one I used was a National brand but would fall off and leaked about a half quart of tranny fluid. I guess it is just a hair smaller than the oem Motorcraft one.
-Replaced Body Mounts with Prothane ones - 2 days
-Scott
Photos when i got my Sport Trac:
Worn Seat:
Worn Steering Wheel:
Worn Body Mount:
Old Tranny and Fluid:
227,064 - Nov 2015
229,811 - Dec 2015
-Scott
Worn Seat:
Worn Body Mount:
